[GRASS-user] Differences Between ERDAS and GRASS About NDVI Statistics
Gökçen Güner gokcenguner at gmail.com
Sun Jan 13 23:55:56 PST 2013
@Nikos:
I'll send information about maps tonight. I'll send 'r.describe -r' output
also.
@Sylvain:
Thank you, I didn't noticed the differences, my friend might had done
histogram strecthing over results, so this may be the reason for -2/2
thing, I will check this.
By the way I'm not sure how we can make data to have same layer extent and
dimension in both programs. I didn't do a special thing before calculation,
I just used g.region and
r.mapcalc methods.
2013/1/14 Sylvain Maillard <sylvain.maillard at gmail.com>
> Hi,
> a quick look at the stats files show some differences:
> - "Dimensions"
> - "Layer Extent"
> - not the same range of data (from -2 to 2 in ERDAS ? oO)
> so that's totally logical to get different mean and stdev ...
> take care to use exactly the same extent/res when you are comparing 2
> files ;)
> cheers,
> Sylvain
> 2013/1/14 Nikos Alexandris <nik at nikosalexandris.net>
>> Gökçen Güner:
>> > > This will not be a specific GRASS question. My friend and I tried to
>> > > calculate NDVIs of same data set and results seem same to us.
>> What kind of images are those, if I may ask? Which sensor?
>> > > But checking statistics of each output we saw that statistics are very
>> > > different. I mean, median, mean, std.dev values of Grass output and
>> Erdas
>> > > output are different.
>> > > We couldn't find an explanation for this situation. What can be
>> > > the reason for this?
>> > There are reasons. For example, different pixel inclusion rules (of
>> course I
>> > have in mind border-near pixels). Other reasons might be the spatial
>> > resolution and extent (remember, GRASS-GIS is strict with that) and the
>> > presence of a MASK.
>> Also,
>> what about NULL or NoData cells? How does ERDAS deal with them -- I don't
>> remember now. How are they defined, if they exist, in your image?
>> What does "r.describe -r" return for the data set(s) in question?
>> Thanks, Nikos
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130114/f26a7197/attachment-0001.html>
