[GRASS-user] Join points and contours
Maris Nartiss maris.gis at gmail.com
Mon Jan 14 23:02:32 PST 2013
You are looking for v.patch
As I know Your next questions, here are answers for them:
You must set up region before interpolating with g.region. Use vect
option to limit boundaries and res to set desired resolution.
Don't forget to use -e option for v.patch to join attribute tables
too. They must have identical structure.
Interpolation tool You want to use is v.surf.rst.
Please, take Your time to read that *fine* manual. And don't skip
"introduction to ..." parts!
Here is link: http://grass.osgeo.org/grass64/manuals/index.html
Maris.
2013/1/14 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> Hi,
> I have two 2D vector layers; spot heights and contours. Both represent
> elevation with an attribute field (say: level).
> Now i need to combine both vectors into one vector so that i can use
> combined vector to generate elevation raster.
> What is the best method to do that?
> Cheers, Brian.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
