[GRASS-user] error: accumulation map does not match with elevation map! (r.basin)
Markus Metz markus.metz.giswork at gmail.com
Thu Jan 24 01:37:51 PST 2013
On Thu, Jan 24, 2013 at 12:43 AM, Giuliano Urgeghe <giuliano.u at gmail.com> wrote:
> I took your advice replacing lines 135-136 and 137 of the file, r.basin.py,
> in the directory  home/grass-addons/grass6/raster/r.basin by editor Kate
> but I have not found any solution to the problem
> also because I used a threshold value different from the default
I found a bug in r.watershed SFD mode, fixed for 6.4 and 6.5 in
r54765-6 (7.0 was not affected). For r.basin, r.watershed could also
be run in MFD mode, the results might be a bit more accurate for
high-resolution DEMs.
Markus M
> thank for your help
> View this message in context: http://osgeo-org.1560.n6.nabble.com/error-accumulation-map-does-not-match-with-elevation-map-tp5029128p5029421.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
