[GRASS-user] grass7- problems caompiling
António M. Rodrigues amcrgrodrigues at gmail.com
Fri Jul 19 05:01:27 PDT 2013
I recently downgraded from ubuntu 11.10 (on a macbookpro 8.1) to 12.04 LTS
(on a samsung 900X3E) - kernel version: 3.5.0-36-generic
On 11.10 I had grass7 running smoothly. On 12.04, after a frustrating
night, I'm still not able to have it running.
I followed instructions on
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS, with
minor alternations....
(yes, I do need 7 rather than 6.4.....)
sudo apt-get install \
  build-essential \
  flex make bison gcc libgcc1 g++ cmake ccache \
  python python-dev python-qt4 python-qt4-dev \
  python-opengl \
  python-wxversion python-wxtools python-wxgtk2.8 \
  python-dateutil libgsl0-dev python-numpy \
  wx2.8-headers wx-common libwxgtk2.8-dev libwxgtk2.8-dbg \
  libwxbase2.8-dev  libwxbase2.8-dbg \
  libncurses5-dev \
  zlib1g-dev gettext \
  libtiff4-dev libpnglite-dev \
  tcl8.5-dev tk8.5-dev \
  libcairo2 libcairo2-dev \
  sqlite3 libsqlite3-dev \
  libpq-dev \
  libreadline6 libreadline6-dev libfreetype6-dev \
  txt2tags \
  libfftw3-3 libfftw3-dev \
  libqt4-core libqt4-dbg libqt4-dev libqt4-gui libqt4-sql libqt4-qt3support
  lsb-qt4 qt4-designer qt4-decommand not foundv-tools qt4-doc qt4-qtconfig \
  libapt-pkg-perl resolvconf \
  libjasper-dev \
  ruby \
  subversion \
  ffmpeg ffmpeg2theora \
  libffmpegthumbnailer-dev \
  libavcodec-dev \
  libxmu-dev \
  libavformat-dev libswscale-dev \
  checkinstall \
  libglu1-mesa-dev libxmu-dev
sudo apt-get install libmysqlclient-dev
sudo apt-get install netcdf-bin libnetcdf-dev
sudo apt-get install libproj-dev
sudo apt-get install libgeos-dev
sudo apt-get install libgdal-dev
    cd fftw-2.1.5/
    CFLAGS="-fPIC" ./configurcommand not founde
    make
    make install
svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
------output --->> Checked out revision 57205.
sudo ./configure \
--enable-64bit \
--with-libs=/lib64 \
--enable-largefile=yes \
--with-nls \
--with-cxx \
--with-proj-share=/usr/share/proj \
--with-geos=/usr/bin/geos-config \
--with-python=yes \
--with-wxwidgets \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-motif \
--with-ffmpeg=yes --with-ffmpeg-includes="/usr/include/libavcodec
/usr/include/libavformat /usr/include/libswscale /usr/include/libavutil" \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-postgres=yes \
--with-postgresql=yes --with-postgres-includes="/usr/include/postgresql" \
--with-sqlite=yes \
--with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
--with-odbc=yes
------------changed /usr/lib64 to /lib64 -> directory /usr/lib64 doens't
exist
if run without sudo, returns:
./configure: 621: ./configure: cannot create ./config.log: Permission denied
make -j2  &&  sudo checkinstall  &&  sudo ldconfig
----------------------------------Output:
GRASS GIS 7.0.svn 57205 compilation log
Started compilation: Thu Jul 18 13:48:21 WEST 2013
Errors in:
/usr/local/src/grass7_trunk/scripts/v.krige
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Jul 18 13:53:46 WEST 2013
make: *** [default] Error 1
When I type grass70, it returns: "command not found".
Am I missing something really simple? IF so, sorry, but could someone help?
Thanks a lot.
António
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130719/d4a93d52/attachment.html>
