[GRASS-user] unexpected i.pansharpen results
Eric Goddard egoddard1010 at gmail.com
Sat Jul 27 18:16:32 PDT 2013
I gave up on that pansharpening attempt. I can test some of my imagery
tomorrow and let you know if I still have issues with it.
On Jul 27, 2013 3:13 PM, "Nikos Alexandris" <nik at nikosalexandris.net> wrote:
> [Back to this old thread!]
> Eric Goddard wrote:
> > Alright, I'm at home on my linux box running grass7, still with the same
> > issue. I converted the inputs for my test area to float:
> > r.mapcalc "ik_c1r2_f.4 = float(ik_c1r2_mss.4 at PERMANENT)"
> > r.mapcalc "ik_c1r2_f.3 = float(ik_c1r2_mss.3 at PERMANENT)"
> > r.mapcalc "ik_c1r2_f.2 = float(ik_c1r2_mss.2 at PERMANENT)"
> > r.mapcalc "ik_c1r2_f.p = float(ik_c1r2_pan at PERMANENT)"
> > and set the color table to grey for each one. (I also remembered to
> change
> > region to reflect the higher resolution of the pan image). I then ran
> > i.pansharpen:
> > i.pansharpen sharpen=ihs ms3=ik_c1r2_f.4 at PERMANENT
> > ms2=ik_c1r2_f.3 at PERMANENTms1=ik_c1r2_f.2 at PERMANENTpan
> =ik_c1r2_f.p at PERMANENTo
> > utput_prefix=ik_ihs_f
> > running r.info on the output bands from i.pansharpen shows that their
> range
> > is still 0-38.
> > The output image is attached.
> > Also, there is one small bug in the output. Line 330: grass.message(_("To
> > visualize output, run: g.region -p rast=%s.red" % out)) -- the %s.red
> > should be %s_red.
> > I've tried using the PCA algorithm and the output looks the same, though
> > the range is different. Later on I'll try with different imagery and see
> > what happens...
> Is this still an issue?  I get akward outputs using i.pansharpen on IKONOS
> imagery.
> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130727/7bf3e6d2/attachment.html>
