[GRASS-user] GRASS64 - r.mapcalc - replacement of specifics value by a mean of nearest neigbour
Nikos Alexandris nik at nikosalexandris.net
Mon Jul 29 06:05:16 PDT 2013
BLANDENIER Lucien wrote:
> Dear Grass users,
> I'm working with rasters maps of large area and I want to calculate surface
> related to specific colours. Before this, I have to replace the surfaces of
> the rivers by the surrounding value (or the mean of the surrounding value).
> I looked at the manual of r.mapcalc but I didn't found how to do this...
> For instance, I want to replace all value between 4 and 7 by the mean of the
> value of the 4 nearest pixels.
> Is there any way of doing this?
> Which command shall I use then for calculating the surface for each color?
> r.stats? or is there a command that directly computes the surface?
Dear Lucien,
did you get past this problem?
I think a combination of r.neighbours (to get the average values from
surrounding cells) and r.recode (for re-categorising values in your input
raster maps so as to get the desired output) + r.stats could do it.
Didn't try anything, of course -- not time.
Thanks, Nikos
