[GRASS-user] NDVI analyses with Landsat 8
Huub Munstege hmunstege at yahoo.com
Wed Jun 12 09:43:35 PDT 2013
Hello Nikos,
thx for the swift reply. I'll check out the options you mentioned but at first sight I noticed that 'i.vi' tool is not available for me ( I'am on 6.4.3-rc, from the AUR package in Archlinux). I.vi is not a command in the 'standard' Grass trunk. Neither is it available as an add-on.
Some more explanation as you asked: previous Landsat 7 images we analyzed with a simple raster calculation with the following formula:
float(Band-4 - Band-3) / (Band-4 + Band-3).
But as you already noticed the bands and ranges have changed under Landsat 8. Various combinations of bands (4,5 and 8) give a result that is at best not so clear cut as the analysis done with L-7. The "bluntly subtraction with 0.12" is based on on a quick scan of the obtained result. Areas without vegetation in our project area should give values in the range between -0.05 - 0. The result of the combination of the 5 and 4 bands in the above formula gives values that are aprroximately 0.12 higher. Therefore the blunt and in-elegant subtraction which is definitely wrong. But it gives us for the time being a better deistinction between cultivated irrigation schemes and their surroundings.
Maybe I am simply too impatient and too eager to work with the new fresh data from L-8. Undoubtedly soon, Grass and the other software will incorporate specific modules that will be tailored to the L-8 sensors.
Cheers and keep up the good work,
Huub
Huub Munstege
BPE 2836
Bamako, Rep. du Mali
Tel:      +223 20226397
Port:     +223 78370695
> De : Nikos Alexandris <nik at nikosalexandris.net>
>À : grass-user at lists.osgeo.org; Huub Munstege <hmunstege at yahoo.com>
>Envoyé le : Mercredi 12 juin 2013 11h23
>Objet : Re: [GRASS-user] NDVI analyses with Landsat 8
>On Wednesday 12 of June 2013 02:05:48 Huub Munstege wrote:
>> Hi there all! Greetings from a happy Grass-root GISser on an Archlinux
>> box...
>Hi!
>> Is there already a way to analyze the new Landsat 8 images (they are already
>> available!)?
>In grass64 you would want to use i.landsat.toar first (with one of the
>correction methods) which supports the new Landsat_8 OLI/TIRS sensor(s).
>> We are in particularly interested in the Normalized
>> Standardized Vegetation Index (NDVI).
>Having (top-of-canopy) reflectances is, if I am not wrong, a *must* in order
>to get the desired ration that reflects the status of the vegetation. You are,
>I guess, probably interested in the "i.vi" module (with "viname=ndvi").
>> We noticed a shift in wavelength
>> range that is best depicted here:
>> http://www.gisagmaps.com/landsat-8-about-refinements/
>Interesting, they "narrowed" the band. They probably know what they are doing.
>New stuff to explore :D
>> Doing the well-known raster map calculation with the bands 5 (NIR) and 4 (R)
>> of L-8 doesn't give a satisfying result. Very bluntly we subtracted 0.12
>> from the 'ndvi' raster derived from L-8.
>Why subtract?  Precisely, if I may ask, did you "threshold" it?  Cut-off
>anything below?
>> Without doubr there must be more
>> elegant and correct solutions. Any ideas are very welcome
>Would you mind to elaborate a bit more?
>Thanks, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130612/1af0a770/attachment-0001.html>
