[GRASS-user] r.contour fails to create contours on large dataset
Eric Goddard egoddard1010 at gmail.com
Fri Mar 8 16:25:35 PST 2013
Yes, only the zero contours are needed. They represent the macro topography
which are later reinterpolated and subtracted from the original DTM.
It works when testing in a smaller region, so I don't think that is the
issue...
On Mar 8, 2013 4:43 PM, "Hamish" <hamish_b at yahoo.com> wrote:
> Eric wrote:
> > The command used to run r.contours:
> > grass.run_command("r.contour", input=lp_subtract,
> > output=LP_contour, minlevel=0, maxlevel=0, step=10)
> minlevel and maxlevel are the same?
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130308/68f73011/attachment.html>
