[GRASS-user] grass-user Digest, Vol 83, Issue 14
    Richard
    rchirgwin at ozemail.com.au
    Sat Mar  9 21:27:47 PST 2013
On 10/03/13 7:00 AM, grass-user-request at lists.osgeo.org wrote:
>   106:32:29.490774E   39:53:38.049989N
>   103:13:40.937174E   41:23:25.138711N
> what's this coordinate.
> How can I do if I want to traverse the entire map with this kind of
> coordinate or some another suggestion?
> The original plan was ready to use bash to get the value of the map
> and then increase the latitude and longitude of the method, which
> traverse the entire map data in the form I want, but this coordinate
> format, I have not seen, how can I use, or do you hava better
> traversal methods? thank you
It's lat and long in hours / minutes / seconds with decimal of seconds.
If you are accustomed to using decimal lat/long, you need to convert
these. It's a simple enough calculation - hours + minutes/60 + seconds/3600
Richard
