[GRASS-user] GRASS GIS 7.0/bundled python/matplolib
Jon Eiriksson jeir at hi.is
Thu Mar 14 13:21:34 PDT 2013
Being unable to import matplotlib in my python scripts in the GRASS GIS
environment (and not able to find binaries for matplotlib 1.2.0 for 32
bit python 2.6, which is needed for the wxgui) - I took the following
workaround steps, perhaps they may be useful to someone or save some
time. Or, even better, perhaps someone knows how to access matplotlib
from the bundled python.
Downloaded python 2.7 and matplotlib 1.2.0 (as well as numpy and
ipython), following recommendations at
http://matplotlib.org/faq/installing_faq.html#os-x-notes
I now have two versions of python on my system (Mac OS X Version
10.7.5). The new installation (2.7), and version 2.6 bundled with
Michael Barton's GRASS GIS 7.0 binaries (William Kingesburye's
frameworks).
In my .bash_profile I have these GRASS and python related lines:
export
PATH=$PATH:/usr/local/mysql/bin:/usr/bin/python:/Applications/GRASS-7.0.app/Contents/MacOS/scripts
export PATH=/Library/Frameworks/GDAL.framework/Programs:$PATH
export
PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:${PATH}
The following python script file was saved to  my home directory:
/Users/joneiriksson/je_01.py
#!/usr/bin/env python-32
import sys
from grass.script import core as grass
from grass.script import db as grass
from array import array
import matplotlib.pyplot as plt
def get_convergence():
     returned_conv_angle = grass.read_command('g.region', flags = 'n')
     conv_angle = grass.parse_key_val(returned_conv_angle)
     return str(conv_angle)
def plot_points_graph():
     xy = []
     zero = 0.0
     xy = [[zero for i in range(2)] for j in range(6)]
     ix,target = 0,5
     while ix <= target:
         xy[ix][0] = ix
         xy[ix][1] = ix
         ix = ix + 1
         print ix
     print xy
     plt.plot(xy, 'ro')
     plt.axis([-1, 6, -1, 6])
     plt.grid(True)
     plt.show()
def main():
     c_angle_string = get_convergence()
     print 'convergence angle string = ',c_angle_string
     plot_points_graph()
     return 0
# this "if" condition instructs execution of code contained in this
script,
# *only* if the script is being executed directly
if __name__ == "__main__": # this allows the script to be used as a
module in other scripts or as a standalone script
     options, flags = grass.parser() #
     sys.exit(main()) #
Note the alias in the first line of the script:
- instead of the normally used
- this notation activates python 2.7 instead of the bundled python 2.6
This enables me to call matplotlib functions from my script, which is
activated in the GRASS GIS Terminal window by the command:
GRASS 7.0.svn (je_location):~ >je_01.py
Other GRASS related python scripts reside in:
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/scripts/
and work as before, using python 2.6 (#!/usr/bin/env python), compatible
with the wxgui
Jon
