[GRASS-user] RE : GRASS 6.4 Windows - How to change current directory
BLANDENIER Lucien lucien.blandenier at unine.ch
Wed Mar 27 07:47:13 PDT 2013
Thank you Nicolas for your answer,
I tried the chdir command but it doesn't work. As for the cd command, I dont' receive an error message but I stay in C:\.
I use the distribution that is include in the QGis distribution.
________________________________________
De : Nicolas Pérenne [nicolas.perenne at free.fr]
Date d'envoi : mercredi 27 mars 2013 15:38
À : BLANDENIER Lucien
Cc: "grass-user ‎[grass-user at lists.osgeo.org]‎"
Objet : Re: [GRASS-user] GRASS 6.4 Windows - How to change current directory
Le 27/03/2013 15:04, BLANDENIER Lucien a écrit :
> Hi all,
> I have some problem to change the current directory on the windows terminal. I used cd : d:\directory but I stay in the same directory...
> Do someone knows how to do that on windows?
> Thanks for your help.
> Lucien
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
if you are using the OSGeo4W distribution, then you might try "chdir"
instead of "cd"
(DOS syntax)... which looks strange to me but it did happen in a test I
recently performed
Nicolas
