[GRASS-user] bug with r.reclass
BLANDENIER Lucien lucien.blandenier at unine.ch
Wed May 15 08:04:10 PDT 2013
Dear all,
I'm facing a problem with r.reclass on GRASS 6.4.2 on Linux mint.
r.reclass seems to have a small bug.
I worked with output name "test" , but then, It didn't work any more with others output names...
This the command I did:
r.reclass --overwrite input=input at mapset output=test rules=path
With the rules:
3 thru 7 = 1
* = NUll
I received the following error when I tried to display the raster or to see the metadata (In french, sorry!):
It says that it is not possible to find the history of the file and to read the boundary file (or limit file)
(Wed May 15 15:28:43 2013)
r.info map=DFO_2006203_LorianSwampsArea_reclass at Merti_Flood_Events_2006_2008_2011
impossible d'obtenir l'historique pour [DFO_2006203_LorianSwampsArea_reclass at Merti_Flood_Events_2006_2008_2011] dans le mapset [Merti_Flood_Events_2006_2008_2011]
impossible de lire le fichier de limites pour [DFO_2006203_LorianSwampsArea_reclass at Merti_Flood_Events_2006_2008_2011 dans Merti_Flood_Events_2006_2008_2011]
ERROR: Unable to read range file
(Wed May 15 15:28:43 2013) La commande s'est terminée (0 sec)
Commande 'd.rast' échouée. Détails : impossible de lire le
[DFO_2006203_LorianSwampsArea_reclass dans
Do someone has an idea what the problem is ?
Regards
Lucien
