[GRASS-user] g.extension error installing install r.hazard.flood
RichardC richtcooper at hotmail.com
Fri May 17 06:40:34 PDT 2013
A few comments/observations:
1. r.hazard.flood.py appears in addons directory (/home/user/.grass6/addons)
after running the g.extension command from the GRASS terminal, but gives the
following error:
GRASS 6.4.3 (Bangkok_UTM47):~ > g.extension extension=r.hazard.flood
/user-notebook/11269.0/dist.i686/docs/html/r.hazard.flood.py.html
/home/user/.grass6/addons/docs/html/
/usr/bin/install -c  -m 644
/home/user/grassdata/Bangkok_UTM47/PERMANENT/.tmp/user-notebook/11269.0/dist.i686/man/man1/r.hazard.flood.py.1
/home/user/.grass6/addons/man/man1/
/usr/bin/install: cannot stat
`/home/user/grassdata/Bangkok_UTM47/PERMANENT/.tmp/user-notebook/11269.0/dist.i686/man/man1/r.hazard.flood.py.1':
No such file or directory
make: *** [install] Error 1
ERROR: Installation failed, sorry. Please check above error messages.
2. Trying to install r.fuzzy.logic from the GRASS terminal also appears to
install (e.g., can see r.fuzzy.logic executable (in
/home/user/.grass6/addons/bin) but errors are given:
GRASS 6.4.3 (Bangkok_UTM47):~ > g.extension extension=r.fuzzy.logic
executable in
/home/user/grassdata/Bangkok_UTM47/PERMANENT/.tmp/user-notebook/11402.0/dist.i686/man/man1/r.fuzzy.logic.1
`/home/user/grassdata/Bangkok_UTM47/PERMANENT/.tmp/user-notebook/11402.0/dist.i686/man/man1/r.fuzzy.logic.1':
3. How would I run r.fuzzy.logic?
Output from the GRASS terminal:
GRASS 6.4.3 (Bangkok_UTM47):~ > r.fuzzy.logic
r.fuzzy.logic: command not found
Output from Layer Manager > Command console:
r.fuzzy.logic
[Errno 2] No such file or directory
Cheers,
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-error-installing-install-r-hazard-flood-tp5053923p5054007.html
Sent from the Grass - Users mailing list archive at Nabble.com.
