[GRASS-user] help with testing the location wizard for the upcoming release
Moritz Lennert mlennert at club.worldonline.be
Mon May 27 01:15:58 PDT 2013
On 26/05/13 13:20, Hamish wrote:
> known issues:
> when reading from a .prj or WKT file, or creating from a geo-
> referenced file, with unspecified datum transform opts, you will
> not be prompted to enter them. the location will be created not
> mentioning them, but in the background PROJ.4 will assign some
> default value (of its choosing) silently.
Trying to define a sector in Belgian Lambert (1972 or 2008) projections,
I see the following oddity (linked to the above ?): Using EPSG codes, I
do get prompted with a choice for either no transformation or one choice
of transform parameters, but even when I chose "Do not apply any datum
transformations" I get a sector with the towgs84 parameter defined for
transformation.
The same happens when I try to define these projections manually by
choosing in a list.
When I enter the proj4 string without the towgs84 parameter it works as
expected, i.e. no towgs84 defined.
Moritz
