[GRASS-user] About Matrix Weights
Nikos Alexandris nik at nikosalexandris.net
Fri Nov 15 00:39:02 PST 2013
Luís Miguel Royo Pérez wrote:
> r.neighbors --overwrite
> input=celdas.aleatorias.1-250 at PERMANENT
> output=media1-250.pesos0
> weight=/home/luismi/Escritorio/prueba_pesos0.txt
Note, the default method is "average".
>  And the Matrix Weight is the next:
> 0 0 0
> 0 0 0
> 0 0 0
> This matrix is the same for 1, 5 and 10 values. I'm putting spaces between
> the numbers... is this correct?
Just to be clear, you mean you have constructed, appart from the "0" matrix above:
1 1 1
1 1 1
1 1 1
5 5 5
5 5 5
5 5 5
10 10 10
10 10 10
10 10 10
And you ran them with the default method=average?
Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131115/5499837b/attachment.html>
