[GRASS-user] cutting rasters with a vector
Nikos Alexandris nik at nikosalexandris.net
Sat Nov 30 02:07:14 PST 2013
Francesco Pirotti UNIPD wrote:
> Just a shot: rasterize a vector polygon and use the rasterized area (or
> areas) as mask?
I wouldn't think otherwise too. In GRASS GIS 6.4.x you have to go this path
along (v.to.rast, r.mask, r.mapcalc).  In GRASS GIS 7, however, you can mask
from a vector directly (i.e. r.mask vector=SomeVectorMap).
Ensure to have set the resolution of the region to the one you desire as an
output. Most of the times it should match the resolution of the raster map(s)
to be masked. Otherwise, a resampling (based on Nearest Neighbour) will take
place.
Nikos
