[GRASS-user] r.average issue with rasters at different resolutions
matteo poletti pollo1_91 at yahoo.it
Sat Oct 19 08:20:05 PDT 2013
Hi Margherita,
Thank you for your reply!
> Da: Margherita Di Leo <diregola at gmail.com>
>Which kind of map is the base map?
Well, shouldn't be the base map just a raster map which assigns the same category to the cells that should be averaged together?
> If you compare the average you get from 2 base maps at different resolutions, you probably will get two different values.
I'm sorry but I don't get the point. The base map I use is always at the same resolution (res=0.2), which is also the resolution of the region. My problem is that I have a cover map with with a different resolution (res=200) and if I use it as it is I get wrong result. The workaround I found is to change the resolution of the cover map before running r.average (r.mapcalc "rescaled_cover_map=original_cover_map") but it's ugly.
Maybe I'm missing something,
Thanks!
Matteo
