[GRASS-user] Road directed network partitioning in k-subgraphs around source node?
G. Allegri giohappy at gmail.com
Thu Sep 5 06:46:52 PDT 2013
Good point Moritz, I will try your trick and I will let you know ;)
2013/9/5 Moritz Lennert <mlennert at club.worldonline.be>
> On 05/09/13 12:50, G. Allegri wrote:
>> I try to explain my problem with an example:
>> I have 3 vehicles that must do some work on a road netowk.
>> The morning they will leave the station and will go to their working area.
>> I need to partition the road network under the following heursitic
>> constraints:
>>   -  the subgraphs must be connected
>>   -  they must have similar graph density
>>   -  the transfer time for the vehicles must be similar
>> I can start simplifying the problem: paritioning the road graph in k
>> subraphs, "radially" around the station, with k the number of vehicles.
> Maybe you can try to create k nodes that are all very close to the
> starting point, but in different directions and then run v.net.alloc ?
> Moritz
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130905/f150a6c0/attachment-0001.html>
