[GRASS-user] Grass 7 ubuntu 13.10
Paul Shapley p.shapley at gmail.com
Sat Apr 19 11:51:15 PDT 2014
I am trying to start Grass 7 svn on Ubuntu 13.10. I used the following
command in terminal:
sudo apt-get update; sudo apt-get install grass70 grass70-gui
When i start Grass with 'grass70' in terminal the Grass 'splash' screen
opens and then promptly crashes. Here is the error:
username at ServerName localhost:~$ grass70
WELCOME TO GRASS 7.0.svn
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      are extremely useful:
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
      http://grass.osgeo.org
      http://www.grass-gis.org
Hit RETURN to continue
Starting GRASS GIS...
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 14: reading
configurations from ~/.fonts.conf is deprecated.
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS 7.0.svn
GRASS homepage:                          http://grass.osgeo.org
This version running through:            Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.svn (dtm_location):~ > Fontconfig warning:
"/etc/fonts/conf.d/50-user.conf", line 14: reading configurations from
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 143, in <module>
    sys.exit(main())
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 136, in main
    app = GMApp(workspaceFile)
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 50, in __init__
    wx.App.__init__(self, False)
  File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7981, in __init__
    self._BootstrapApp()
line 7555, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/usr/lib/grass70/etc/gui/wxpython/wxgui.py", line 84, in OnInit
    workspace = self.workspaceFile)
  File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py", line 110, in
__init__
    self._menuTreeBuilder = LayerManagerMenuData()
  File "/usr/lib/grass70/etc/gui/wxpython/lmgr/menudata.py", line 40, in
__init__
    MenuTreeModelBuilder.__init__(self, filename, expandAddons=expandAddons)
  File "/usr/lib/grass70/etc/gui/wxpython/core/menutree.py", line 69, in
__init__
    xmlTree = etree.parse(filename)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parse
    tree.parse(source, parser)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
    self._root = parser.close()
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1654, in close
    self._raiseerror(v)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1506, in
_raiseerror
    raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
*Paul Shapley*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140419/f235f253/attachment.html>
