[GRASS-user] r.horizon distance units
Tyler Smith tyler at plantarum.ca
Tue Aug 12 06:10:08 PDT 2014
On Tue, Aug 12, 2014, at 01:48 AM, Nikos Alexandris wrote:
> In all 6.x series as well as in GRASS ver. 7.0, the manual for
> r.horizon notes:
> At the moment the elevation and maximum distance must be measured in
> meters, even if you use geographical coordinates (longitude/latitude).
> If your projection is based on distance (easting and northing), these
> too must be in meters. The buffer parameters must be in the same units
> as the raster coordinates.
Thank you Nikos.
I read that passage many times, I don't know how I missed the info
hiding there in plain sight. I guess I need more sleep!
Best,
Tyler
