[GRASS-user] r.sun for selected points
Tyler Smith tyler at plantarum.ca
Thu Aug 14 13:05:37 PDT 2014
On 14/08/14 12:46 PM, Nikos Alexandris wrote:
> Questions and ideas that might help:
> How dense is your point data-set?  What is the spatial resolution your
> aiming at?  Could latitude be your criterion in eliminating (somehow)
> points?  It's an important factor in estimating solar irradiation.
> Maybe take ideas from existing maps (10km seems to be a high
> resolution value for solar irradiance mapping).
Thanks, Nikos.
We are trying to model habitat for a plant species that appears to
prefer particular slope positions, often in steep ravines. So we need a
very high resolution to capture shading from surrounding topography.
20m-sq cells is the resolution of our DEM, and biologically we can't use
a coarser resolution. The data set is fairly dense, such that I can't
see any obvious ways to simply block out areas within the larger map. I
may try the scripting approach that Vaclav suggested instead.
Best,
Tyler
