[GRASS-user] Grass-7.0 beta3 fails to launch
Vaclav Petras
wenzeslaus at gmail.com
Tue Aug 19 07:20:45 PDT 2014
Can you please test a improved check for Cygwin? I would need to
replace etc\grass70.py
file in your GRASS installation by the file attached to this email.
Here is a example of path to that file:
C:\Program Files (x86)\GRASS GIS 7.0.0beta3\etc\grass70.py
You will probably need administrator rights to do it.
You can write the result directly to the ticket I created (you need OSGeo
ID for it):
http://trac.osgeo.org/grass/ticket/2395
For the record, I have used
if sys.platform == 'cygwin':
instead of
if os.getenv('CYGWIN'):
on the line 900.
On Tue, Aug 19, 2014 at 10:00 AM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Tue, Aug 19, 2014 at 2:58 AM, Sindile Bidla <sindile.bidla at gmail.com>
> wrote:
>> Dear List
>> I am using Grass-7.0 beta3 installed via osgeo4w 32bit installer on
>> Windows 8 64 bit. I have also installed Grass-7.0 beta3 via the windows
>> installer and have the same problem.
>> I get the error below and not sure what is happening:
>> Launching <wxpython> GUI in the background, please wait...
>> /usr/bin/bash.exe: Command not found
> Hello, I looked to the source code and I think that there are two
> problems. One is that GRASS is using some unreliable method of determining
> if it is running as Cygwin application or native one. OSGeo4W and stadalone
> are both MS Windows native applications but in your case GRASS thinks that
> it is Cygwin one.
> The other problem is what caused GRASS to think this. It seems to me you
> have CYGWIN variable in your environment. If you remove this variable,
> GRASS should start. But note that I don't know why you have CYGWIN in your
> environment (it might be needed by some other application).
> See more details in the ticket I've created:
> Thanks for trying OSGeo4W, standalone and 6.4 versions,
> Vaclav
>> Cleaning up temporary files...
>> Done.
>> Goodbye from GRASS GIS
>> C:\Users\sindile\Desktop>ERROR: Variable 'LOCATION_NAME' not set
>> Traceback (most recent call last):
>> File "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\wxgui.py",
>> line 34,
>> in <module>
>> from lmgr.frame import GMFrame
>> File
>> "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\lmgr\frame.py", line
>> 50, in <module>
>> from lmgr.layertree import LayerTree, LMIcons
>> File
>> "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\lmgr\layertree.py",
>> line 37, in <module>
>> from mapdisp.frame import MapFrame
>> File
>> "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\mapdisp\frame.py", l
>> ine 66, in <module>
>> class MapFrame(SingleMapFrame):
>> File
>> ine 72, in MapFrame
>> page = None, Map = Map(), auimgr = None, name = 'MapWindow',
>> **kwargs):
>> File
>> "C:\OSGeo4W\apps\grass\grass-7.0.0beta3\gui\wxpython\core\render.py", lin
>> e 401, in __init__
>> if not self.GetWindow():
>> File
>> e 460, in GetWindow
>> filename = os.path.join (env['GISDBASE'],
>> KeyError: 'GISDBASE'
>> I also have Grass 6.4.4 installed via osgeo4w and it works fine.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140819/d1fda613/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140819/d1fda613/attachment-0001.py>
