[GRASS-user] GRASS 7.0.0
rengifo rengifoo at yahoo.de
Fri Aug 22 13:16:29 PDT 2014
Hi Vaclav, Thank for you quick reply.
>can you please describe how did you installed GRASS GIS? Compiled
yourself?
Yes, I compiled Grass70 following partly the instructions give in this
official site: http://grasswiki.osgeo.org/wiki/Compile_and_Install
>Is the gis_set.py file present somewhere?
Apparently not.  I use the following command dpkg -l | grep gis_set.py,
but without results. Do you other manner t find out if  the gis_set.py
in present? I would appreciate it.
On to., 2014-08-21 at 09:08 -0400, Vaclav Petras wrote:
> Hi Rengifo,
> On Thu, Aug 21, 2014 at 7:28 AM, Rengifo Ortega <rengifoo at yahoo.de>
> wrote:
> > Dear Grass users,
> > recently I installed GRASS 7.0.0 on ubuntu 14.04 (32 bits). When I
> tried to open  by typing  grass70 command I get the  following error
> message: python: can't open file
> '/usr/lib/grass70/gui/wxpython/gis_set.py': [Errno 2] No such file or
> directory
> yourself? Is the gis_set.py file present somewhere?
> >  I also have  version 6.4.3 pefectly working from before, but I
> would like to migrate to Grass 70 as soon as posible. Any suggestions
> how to solve this issue?
> > thanks in advance..
> > Rengifo Ortega
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
