[GRASS-user] problem to install grass70 on ubuntu 12.04
Markus Neteler neteler at osgeo.org
Wed Aug 27 11:08:29 PDT 2014
On Wed, Aug 27, 2014 at 6:52 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Sergio,
> On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
> <vignalisergio30 at gmail.com> wrote:
>> Hi,
>> I've just tried to install grass70 on ubuntu 12.04 by these command
>> sudo add-apt-repository ppa:grass/grass-stable
>> sudo apt-get update
>> sudo apt-get install grass70 grass70-gui
>> the error says that there are damaged or blocked packages
> To better understand, I have created a virtual machine with Ubuntu
> 12.04 and tried myself. In fact:
> pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
>  grass70 : Depends: grass70-core but it is not going to be installed
>  grass70-gui : Depends: grass70-core but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> So I tried harder:
> pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core grass70-gui
>  grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
>                 Depends: libgeos-c1 (>= 3.4.2) but it is not going to
> be installed
>                 Depends: libproj0 (>= 4.8.0-1) but it is not going to
> be installed
>                 Recommends: gdal-bin but it is not going to be installed
>                 Recommends: proj-bin but it is not going to be installed
>                 Breaks: grass70 (< 7.0.0+0ubuntu3~)
> Not sure what the next step is (I am more experienced with RPM based systems).
Just to complete the tests, also this fails at time:
           Depends: grass70-gui but it is not going to be installed
> Likely it can be solved :-)
Markus
