[GRASS-user] GRASS window timing question
Zoltan zoltan at sonic.net
Wed Aug 27 13:42:59 PDT 2014
I'm new to GRASS and am running on a 64-bit Windows-7 OS. The app is
working quite well for me overall but I'm having one issue with timing
on the GRASS window. I kind of suspect there's no fix for this but I'll
ask anyway.
I am launching GRASS from a batch file with the GRASS_BATCH_JOB variable
set. The batch job just calls g.parser on a text file, like this:
     "C:\ProgramFiles\GRASS\bin\g.parser.exe" cmds.txt
The cmds.txt file looks roughly like this:
     g.region ... parms ...
     d.mon start=wx0 width=1700 height=1000
     ...some v.proj commands...
     d.vect map=...one of the maps...
     d.vect ...a few more d.vect commands...
The problem I'm having is this: If the actual display window is not
visible when the d.vect commands run, the graphics fail to draw properly
and I also get errors in some cases.
If I wait for the display window to appear on the monitor before running
the d.vect commands, all is well. This seems logical...something about
the display object is not fully initialized when the d.vect commands run
so things don't work.
I do have a workaround, which is just to insert a sleep statement to
give the window time to initialize but it needs to be rather long and it
would be nice if there were some other way to wait for window
initialization.
Is there already a way to do this, or would that be an enhancement request?
Again, thanks for the great app, and thanks in advance if you can help
on this question!
     Zoltan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/aa50f95e/attachment.html>
