[GRASS-user] GRASS window timing question
roy royroge at outlook.com
Thu Aug 28 01:13:19 PDT 2014
is it maybe possible to concatenate commands using "&&"
something like
d.mon ... && d.vect ...
this should work in bash, don't know in DOS ...
Il 27/08/2014 22:42, Zoltan ha scritto:
> Hi,
> I'm new to GRASS and am running on a 64-bit Windows-7 OS. The app is
> working quite well for me overall but I'm having one issue with timing
> on the GRASS window. I kind of suspect there's no fix for this but
> I'll ask anyway.
> I am launching GRASS from a batch file with the GRASS_BATCH_JOB
> variable set. The batch job just calls g.parser on a text file, like this:
>     "C:\ProgramFiles\GRASS\bin\g.parser.exe" cmds.txt
> The cmds.txt file looks roughly like this:
>     g.region ... parms ...
>     d.mon start=wx0 width=1700 height=1000
>     ...some v.proj commands...
>     d.vect map=...one of the maps...
>     d.vect ...a few more d.vect commands...
> The problem I'm having is this: If the actual display window is not
> visible when the d.vect commands run, the graphics fail to draw
> properly and I also get errors in some cases.
> If I wait for the display window to appear on the monitor before
> running the d.vect commands, all is well. This seems
> logical...something about the display object is not fully initialized
> when the d.vect commands run so things don't work.
> I do have a workaround, which is just to insert a sleep statement to
> give the window time to initialize but it needs to be rather long and
> it would be nice if there were some other way to wait for window
> initialization.
> Is there already a way to do this, or would that be an enhancement
> request?
> Again, thanks for the great app, and thanks in advance if you can help
> on this question!
>     Zoltan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140828/cb1099e8/attachment.html>
