[GRASS-user] problem to install grass70 on ubuntu 12.04 and dependencies for kriging
John Nicholls johnnicholls at fastmail.fm
Fri Aug 29 05:17:23 PDT 2014
Hi Alex
I am still trying to use v.krige, and as a test-run on one data set I've
set g.region res=10 to check I have all the dependencies installed.
v.krige seems to be running but, perhaps foolishly, I was expecting to
see some progress on the 'progress bar' for v.krige in the GUI.
Here is the current command output from v.krige I have:
(Fri Aug 29 12:23:29 2014)
v.krige input=tv1236_out_shft at user1 column=z1
output=tv1236_out_shft_kriging_res10 package=gstat --overwrite
output_var=tv1236_out_shft_kriging.var_res10
Loading dependencies, please wait...
rgeos version: 0.3-6, (SVN revision 450)
 GEOS runtime version: 3.4.2-CAPI-1.8.2 r3921
 Polygon checking: TRUE
Attaching package: ‘XML’
The following object is masked from ‘package:tools’:
    toHTML
GRASS GIS interface loaded with GRASS version: GRASS 7.0.0svn (2014)
and location: 14009
Checking rgeos availability: TRUE
Loading required package: automap
Processing 744 cells. Computing time raises exponentially
with resolution.
Importing data...
Loading required package: rgdal
rgdal: version: 0.8-16, (SVN revision 498)
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.10.1, released 2013/08/26
Path to GDAL shared files: /usr/share/gdal/1.10
Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
Path to PROJ.4 shared files: (autodetected)
Nothing further after 2 hours. This is 4ha of data, points every 10cm
spaced along lines 0.5 apart. But the region set to 10 should mean some
progress with v.krige by now, presumably(?).
Just to confirm I have libgeos-dev, libproj-dev, and build essential
successfully installed, and rpy2. Are there any other dependencies or R
packages I require to get v.krige working?
There are various posts on v.krige, the
grasswiki.osgeo.org/wiki/V.krige_GSoC_2009 refers to installation of
maptools (install.packages ("maptools", dep=T), I presume automap
replaces maptools at this stage? I tried to install maptools in R and
got the following output:
> install.packages("maptools", dep=T)
Installing package into ‘/home/john/R/i686-pc-linux-gnu-library/3.0’
(as ‘lib’ is unspecified)
--- Please select a CRAN mirror for use in this session ---
Warning: dependency ‘goftest’ is not available
also installing the dependencies ‘deldir’, ‘abind’, ‘tensor’,
‘polyclip’, ‘spatstat’, ‘PBSmapping’
trying URL 'http://cran.rstudio.com/src/contrib/deldir_0.1-6.tar.gz'
Content type 'application/x-gzip' length 57030 bytes (55 Kb)
opened URL
downloaded 55 Kb
trying URL 'http://cran.rstudio.com/src/contrib/abind_1.4-0.tar.gz'
Content type 'application/x-gzip' length 19642 bytes (19 Kb)
opened URL
downloaded 19 Kb
trying URL 'http://cran.rstudio.com/src/contrib/tensor_1.5.tar.gz'
Content type 'application/x-gzip' length 2518 bytes
opened URL
downloaded 2518 bytes
trying URL 'http://cran.rstudio.com/src/contrib/polyclip_1.3-0.tar.gz'
Content type 'application/x-gzip' length 73184 bytes (71 Kb)
opened URL
downloaded 71 Kb
trying URL 'http://cran.rstudio.com/src/contrib/spatstat_1.38-1.tar.gz'
Content type 'application/x-gzip' length 5186334 bytes (4.9 Mb)
opened URL
downloaded 4.9 Mb
trying URL
'http://cran.rstudio.com/src/contrib/PBSmapping_2.67.60.tar.gz'
Content type 'application/x-gzip' length 4503312 bytes (4.3 Mb)
opened URL
downloaded 4.3 Mb
trying URL 'http://cran.rstudio.com/src/contrib/maptools_0.8-30.tar.gz'
Content type 'application/x-gzip' length 1505747 bytes (1.4 Mb)
opened URL
downloaded 1.4 Mb
* installing *source* package ‘deldir’ ...
** package ‘deldir’ successfully unpacked and MD5 sums checked
** libs
gfortran   -fpic  -O3 -pipe  -g  -c acchk.f -o acchk.o
gfortran   -fpic  -O3 -pipe  -g  -c addpt.f -o addpt.o
gfortran   -fpic  -O3 -pipe  -g  -c adjchk.f -o adjchk.o
gfortran   -fpic  -O3 -pipe  -g  -c binsrt.f -o binsrt.o
gfortran   -fpic  -O3 -pipe  -g  -c circen.f -o circen.o
gfortran   -fpic  -O3 -pipe  -g  -c cross.f -o cross.o
gfortran   -fpic  -O3 -pipe  -g  -c delet.f -o delet.o
gfortran   -fpic  -O3 -pipe  -g  -c delet1.f -o delet1.o
gfortran   -fpic  -O3 -pipe  -g  -c delout.f -o delout.o
gfortran   -fpic  -O3 -pipe  -g  -c delseg.f -o delseg.o
gfortran   -fpic  -O3 -pipe  -g  -c dirout.f -o dirout.o
gfortran   -fpic  -O3 -pipe  -g  -c dirseg.f -o dirseg.o
gfortran   -fpic  -O3 -pipe  -g  -c dldins.f -o dldins.o
gfortran   -fpic  -O3 -pipe  -g  -c initad.f -o initad.o
gfortran   -fpic  -O3 -pipe  -g  -c insrt.f -o insrt.o
gfortran   -fpic  -O3 -pipe  -g  -c insrt1.f -o insrt1.o
gfortran   -fpic  -O3 -pipe  -g  -c intri.f -o intri.o
gfortran   -fpic  -O3 -pipe  -g  -c locn.f -o locn.o
gfortran   -fpic  -O3 -pipe  -g  -c master.f -o master.o
gfortran   -fpic  -O3 -pipe  -g  -c mnnd.f -o mnnd.o
gfortran   -fpic  -O3 -pipe  -g  -c pred.f -o pred.o
gfortran   -fpic  -O3 -pipe  -g  -c qtest.f -o qtest.o
gfortran   -fpic  -O3 -pipe  -g  -c qtest1.f -o qtest1.o
gfortran   -fpic  -O3 -pipe  -g  -c stoke.f -o stoke.o
gfortran   -fpic  -O3 -pipe  -g  -c succ.f -o succ.o
gfortran   -fpic  -O3 -pipe  -g  -c swap.f -o swap.o
gfortran   -fpic  -O3 -pipe  -g  -c testeq.f -o testeq.o
gfortran   -fpic  -O3 -pipe  -g  -c triar.f -o triar.o
gfortran   -fpic  -O3 -pipe  -g  -c trifnd.f -o trifnd.o
gcc -std=gnu99 -shared -o deldir.so acchk.o addpt.o adjchk.o binsrt.o
circen.o cross.o delet.o delet1.o delout.o delseg.o dirout.o dirseg.o
dldins.o initad.o insrt.o insrt1.o intri.o locn.o master.o mnnd.o pred.o
qtest.o qtest1.o stoke.o succ.o swap.o testeq.o triar.o trifnd.o
-lgfortran -lm -lquadmath -L/usr/lib/R/lib -lR
installing to /home/john/R/i686-pc-linux-gnu-library/3.0/deldir/libs
** R
** inst
** preparing package for lazy loading
** help
*** installing help indices
** building package indices
** testing if installed package can be loaded
* DONE (deldir)
* installing *source* package ‘abind’ ...
** package ‘abind’ successfully unpacked and MD5 sums checked
** R
** help
* DONE (abind)
* installing *source* package ‘tensor’ ...
** package ‘tensor’ successfully unpacked and MD5 sums checked
** R
** help
* DONE (tensor)
* installing *source* package ‘polyclip’ ...
** package ‘polyclip’ successfully unpacked and MD5 sums checked
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for int64_t... yes
     In src/clipper.h, signed 64-bit integers (cInt)
     will be declared as 'int64_t'
checking for uint64_t... yes
     In src/clipper.h, unsigned 64-bit integers (cUInt)
     will be declared as 'uint64_t'
configure: creating ./config.status
config.status: creating src/Makevars
** libs
g++ -I/usr/share/R/include -DNDEBUG -DPOLYCLIP_LONG64="int64_t"
-DPOLYCLIP_ULONG64="uint64_t"     -fpic  -O3 -pipe  -g  -c clipper.cpp
-o clipper.o
-DPOLYCLIP_ULONG64="uint64_t"     -fpic  -O3 -pipe  -g  -c interface.cpp
-o interface.o
g++ -shared -o polyclip.so clipper.o interface.o -L/usr/lib/R/lib -lR
installing to /home/john/R/i686-pc-linux-gnu-library/3.0/polyclip/libs
** R
** byte-compile and prepare package for lazy loading
** help
* DONE (polyclip)
* installing *source* package ‘PBSmapping’ ...
** package ‘PBSmapping’ successfully unpacked and MD5 sums checked
** libs
gcc -std=gnu99 -I/usr/share/R/include -DNDEBUG      -fpic  -O3 -pipe  -g
 -c PBSmapping.c -o PBSmapping.o
g++ -I/usr/share/R/include -DNDEBUG      -fpic  -O3 -pipe  -g  -c
clipper.cpp -o clipper.o
clipperWrapper.cpp -o clipperWrapper.o
 -c convGSHHS.c -o convGSHHS.o
 -c conversions.c -o conversions.o
 -c gshhs.c -o gshhs.o
 -c polygons.c -o polygons.o
 -c thin.c -o thin.o
g++ -shared -o PBSmapping.so PBSmapping.o clipper.o clipperWrapper.o
convGSHHS.o conversions.o gshhs.o polygons.o thin.o -L/usr/lib/R/lib -lR
installing to /home/john/R/i686-pc-linux-gnu-library/3.0/PBSmapping/libs
** R
** data
** demo
** inst
** help
** installing vignettes
   ‘PBSmappingIntro.Rnw’
* DONE (PBSmapping)
* installing *source* package ‘maptools’ ...
** package ‘maptools’ successfully unpacked and MD5 sums checked
** libs
 -c Rcentroid.c -o Rcentroid.o
 -c Rgshhs.c -o Rgshhs.o
 -c Rshapeget.c -o Rshapeget.o
 -c Rshapeinfo.c -o Rshapeinfo.o
 -c Rshapewrite.c -o Rshapewrite.o
 -c Rshapewrite1.c -o Rshapewrite1.o
 -c insiders.c -o insiders.o
 -c pip.c -o pip.o
 -c shpopen.c -o shpopen.o
shpopen.c: In function ‘SHPOpen’:
shpopen.c:507:10: warning: ignoring return value of ‘fread’, declared
with attribute warn_unused_result [-Wunused-result]
     fread( pabyBuf, 100, 1, psSHP->fpSHP );
 -c shptree.c -o shptree.o
shptree.c: In function ‘SHPSearchDiskTree’:
shptree.c:829:10: warning: ignoring return value of ‘fread’, declared
     fread( abyBuf, 16, 1, fp );
shptree.c: In function ‘SHPSearchDiskTreeNode’:
shptree.c:731:10: warning: ignoring return value of ‘fread’, declared
     fread( &offset, 4, 1, fp );
shptree.c:734:10: warning: ignoring return value of ‘fread’, declared
     fread( adfNodeBoundsMin, sizeof(double), 2, fp );
shptree.c:735:10: warning: ignoring return value of ‘fread’, declared
     fread( adfNodeBoundsMax, sizeof(double), 2, fp );
shptree.c:744:10: warning: ignoring return value of ‘fread’, declared
     fread( &numshapes, 4, 1, fp );
shptree.c:771:14: warning: ignoring return value of ‘fread’, declared
         fread( *ppanResultBuffer + *pnResultCount,
shptree.c:786:10: warning: ignoring return value of ‘fread’, declared
     fread( &numsubnodes, 4, 1, fp );
gcc -std=gnu99 -shared -o maptools.so Rcentroid.o Rgshhs.o Rshapeget.o
Rshapeinfo.o Rshapewrite.o Rshapewrite1.o insiders.o pip.o shpopen.o
shptree.o -L/usr/lib/R/lib -lR
installing to /home/john/R/i686-pc-linux-gnu-library/3.0/maptools/libs
** R
** data
** inst
** help
* DONE (maptools)
ERROR: dependency ‘goftest’ is not available for package ‘spatstat’
* removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/spatstat’
The downloaded source packages are in
        ‘/tmp/Rtmpj9ZjtH/downloaded_packages’
Warning message:
In install.packages("maptools", dep = T) :
  installation of package ‘spatstat’ had non-zero exit status
Can you offer any further advice on missing dependencies of R packages I
require for v.krige?
Thanks,
John.
, to On Fri, Aug 29, 2014, at 01:03 PM, John Nicholls wrote:
> Thanks Alex.
> I have done the installation of libgeos-dev, libproj-dev and
> build-essential, and there also ssemed to be the essential GDAL missing.
> v.krige now loads all the dependencies in Grass7 and I'm just trying to
> process some data.
> Thanks for all your help
> John.
> On Thu, Aug 28, 2014, at 05:55 PM, Alex Mandel wrote:
> > You need to install libgeos-dev, libproj-dev etc and build-essential.
> > Installation of R packages on Linux often requires compiling so you need
> > all the source headers and compilers for it to work.
> > -Alex
> > On 08/28/2014 02:57 AM, John Nicholls wrote:
> > > Hi
> > > Thanks for the help to get Grass7 running on my laptop.
> > > I followed the workaround "sudo apt-get install grass70-core
> > > grass70-gui" and now have grass70 running on Ubuntu 14.04 LTS:
> > > I am trying to use the v.krige command in Grass7, and when doing so
> > > receive the following:
> > > Checking rgeos availability: FALSE
> > >  	Note: when rgeos is not available, polygon geometry
> > >  	computations in maptools depend on gpclib,
> > >  	which has a restricted licence. It is disabled by default;
> > >  	to enable gpclib, type gpclibPermit()
> > > ERROR: R package(s) rgeos, gstat, spgrass6 missing. Install it/them and
> > > re-run v.krige.
> > > I've installed python-rpy2.2.3.9-1 via the Ubuntu package manager, and
> > > enabled gpclib.
> > > Following the instructions in
> > > http://grass.osgeo.org/grass65/manuals/v.krige.py.html I've typed in
> > >  install.packages("rgeos", dep=T)
> > >   install.packages("gstat", dep=T)
> > >   install.packages("spgrass6", dep=T)
> > >   install.packages("automap", dep=T)
> > > Unfortunately I'm getting errors in the installation of "rgeos",
> > > "gstat", "spgrass6", and "automap", which are detailed below. Does
> > > anyone know where I might be going wrong. The version of R installed on
> > > my laptop is R version 3.0.2 (2013-09-25) -- "Frisbee Sailing", and I
> > > have a version of RKward also installed.
> > > I am neither a Grass nor R expert, needless to say....
> > > also installing the dependency ‘XML’
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/XML_3.98-1.1.tar.gz'
> > > Content type 'application/x-gzip' length 1582216 bytes (1.5 Mb)
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/rgeos_0.3-6.tar.gz'
> > > Content type 'application/x-gzip' length 240510 bytes (234 Kb)
> > > opened URL
> > > downloaded 234 Kb
> > > * installing *source* package ‘XML’ ...
> > > ** package ‘XML’ successfully unpacked and MD5 sums checked
> > > checking for gcc... gcc
> > > checking for C compiler default output file name... rm: cannot remove
> > > 'a.out.dSYM': Is a directory
> > > a.out
> > > checking whether the C compiler works... yes
> > > checking whether we are using the GNU C compiler... yes
> > > checking whether gcc accepts -g... yes
> > > checking for gcc option to accept ISO C89... none needed
> > > checking how to run the C preprocessor... gcc -E
> > > checking for sed... /bin/sed
> > > checking for pkg-config... /usr/bin/pkg-config
> > > checking for xml2-config... no
> > > Cannot find xml2-config
> > > ERROR: configuration failed for package ‘XML’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/XML’
> > > * installing *source* package ‘rgeos’ ...
> > > ** package ‘rgeos’ successfully unpacked and MD5 sums checked
> > > configure: CC: gcc -std=gnu99
> > > configure: CXX: g++
> > > configure: rgeos: 0.3-4
> > > checking for /usr/bin/svnversion... no
> > > configure: svn revision: 450
> > > checking geos-config usability... ./configure: line 2056: geos-config:
> > > command not found
> > > no
> > > configure: error: geos-config not usable
> > > ERROR: configuration failed for package ‘rgeos’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/rgeos’
> > > 	‘/tmp/RtmpRYggF0/downloaded_packages’
> > > Warning messages:
> > > 1: In install.packages("rgeos", dep = T) :
> > >   installation of package ‘XML’ had non-zero exit status
> > > 2: In install.packages("rgeos", dep = T) :
> > >   installation of package ‘rgeos’ had non-zero exit status
> > > also installing the dependencies ‘spacetime’, ‘rgdal’, ‘rgeos’
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/spacetime_1.1-1.tar.gz'
> > > Content type 'application/x-gzip' length 2269252 bytes (2.2 Mb)
> > > opened URL
> > > downloaded 2.2 Mb
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/rgdal_0.8-16.tar.gz'
> > > Content type 'application/x-gzip' length 1616275 bytes (1.5 Mb)
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > opened URL
> > > downloaded 234 Kb
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/gstat_1.0-19.tar.gz'
> > > Content type 'application/x-gzip' length 2045717 bytes (2.0 Mb)
> > > opened URL
> > > downloaded 2.0 Mb
> > > * installing *source* package ‘rgdal’ ...
> > > ** package ‘rgdal’ successfully unpacked and MD5 sums checked
> > > configure: CXX: g++
> > > configure: rgdal: 0.8-15
> > > configure: svn revision: 498
> > > configure: gdal-config: gdal-config
> > > checking gdal-config usability... ./configure: line 2119: gdal-config:
> > > command not found
> > > no
> > > Error: gdal-config not found
> > > The gdal-config script distributed with GDAL could not be found.
> > > If you have not installed the GDAL libraries, you can
> > > download the source from  http://www.gdal.org/
> > > If you have installed the GDAL libraries, then make sure that
> > > gdal-config is in your path. Try typing gdal-config at a
> > > shell prompt and see if it runs. If not, use:
> > >  --configure-args='--with-gdal-config=/usr/local/bin/gdal-config'
> > > with appropriate values for your installation.
> > > ERROR: configuration failed for package ‘rgdal’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/rgdal’
> > > configure: CXX: g++
> > > command not found
> > > no
> > > ERROR: dependency ‘rgeos’ is not available for package ‘spacetime’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/spacetime’
> > > ERROR: dependency ‘spacetime’ is not available for package ‘gstat’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/gstat’
> > > Warning messages:
> > > 1: In install.packages("gstat", dep = T) :
> > >   installation of package ‘rgdal’ had non-zero exit status
> > > 2: In install.packages("gstat", dep = T) :
> > > 3: In install.packages("gstat", dep = T) :
> > >   installation of package ‘spacetime’ had non-zero exit status
> > > 4: In install.packages("gstat", dep = T) :
> > >   installation of package ‘gstat’ had non-zero exit status
> > > also installing the dependencies ‘XML’, ‘rgdal’
> > > trying URL
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > 'http://www.freestatistics.org/cran/src/contrib/spgrass6_0.8-3.tar.gz'
> > > Content type 'application/x-gzip' length 274678 bytes (268 Kb)
> > > opened URL
> > > downloaded 268 Kb
> > > a.out
> > > configure: CXX: g++
> > > command not found
> > > no
> > > ERROR: dependency ‘XML’ is not available for package ‘spgrass6’
> > > * removing ‘/home/john/R/i686-pc-linux-gnu-library/3.0/spgrass6’
> > > Warning messages:
> > > 1: In install.packages("spgrass6", dep = T) :
> > > 2: In install.packages("spgrass6", dep = T) :
> > > 3: In install.packages("spgrass6", dep = T) :
> > >   installation of package ‘spgrass6’ had non-zero exit status
> > > trying URL
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > opened URL
> > > downloaded 1.5 Mb
> > > trying URL
> > > opened URL
> > > downloaded 268 Kb
> > > a.out
> > > configure: CXX: g++
> > > command not found
> > > no
> > > Warning messages:
> > > On Wed, Aug 27, 2014, at 10:10 PM, Markus Neteler wrote:
> > >> On Wed, Aug 27, 2014 at 9:08 PM, César Augusto Ramírez Franco
> > >> <caesarivs at gmail.com> wrote:
> > >>> I don't know why, but there appears to be a conflict between grass70 and
> > >>> grass70-core packages.
> > >>> I've been using that PPA on 14.04 but the package grass70 is not installed
> > >>> in my system:
> > >>> And grass is working OK, so I'd say the workaround should be issuing:
> > >>> sudo apt-get install grass70-core grass70-gui
> > >> pgis at pgis-ubuntu64-vm:~$ sudo apt-get install grass70-core grass70-gui
> > >> Reading package lists... Done
> > >> Building dependency tree
> > >> Reading state information... Done
> > >> Some packages could not be installed. This may mean that you have
> > >> requested an impossible situation or if you are using the unstable
> > >> distribution that some required packages have not yet been created
> > >> or been moved out of Incoming.
> > >> The following information may help to resolve the situation:
> > >> The following packages have unmet dependencies:
> > >>  grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
> > >>                 Depends: libgeos-c1 (>= 3.4.2) but it is not going to
> > >> be installed
> > >>                 Depends: libproj0 (>= 4.8.0-1) but it is not going to
> > >> be installed
> > >>                 Recommends: gdal-bin but it is not going to be installed
> > >>                 Recommends: proj-bin but it is not going to be installed
> > >> E: Unable to correct problems, you have held broken packages.
> > >> ... also failing today (Ubuntu 12.04 here)
> > >> Markus
> > >> _______________________________________________
> > >> grass-user mailing list
> > >> grass-user at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/grass-user
> http://www.fastmail.fm - The professional email service
http://www.fastmail.fm - The way an email service should be
