[GRASS-user] i.segment.hierarchical on windows?
Helmut Kudrnovsky hellik at web.de
Wed Dec 10 00:48:05 PST 2014
>>     FCELL = (np.float, np.float16, np.float32)
>> AttributeError: 'module' object has no attribute 'float16'
>Ok, this should be fix in r63462.
AFAIK float16 data type was introduced in NumPy 1.6, while OSGeo4W based
winGRASS uses 1.5.
>If I  don't put an empty html file the make command give me an
>error... Of course I should add some more details, but I didn't have
>time for this.
I've added a manual skeleton by r63463
(http://lists.osgeo.org/pipermail/grass-commit/2014-December/034373.html)
>I don't know how to fix this... you should have the same problem with
>other modules that are using their own libraries like r.modis, aren't
>you?
I'll have a look.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-segment-hierarchical-on-windows-tp5177091p5177184.html
Sent from the Grass - Users mailing list archive at Nabble.com.
