[GRASS-user] Conversion from point data to raster in GRASS
Micha Silver micha at arava.co.il
Thu Dec 18 12:50:58 PST 2014
I see below that your vector has 10,182 points. This raster has
62,264,281 raster cells. So in the raster you have about 6000 cells with
no value (0) for each 1 with some value. I would guess that if you zoom
in very close to some points in the original vector, you will see that
those raster cells have a value.
And again, you most likely should consider some interpolation method.
On 12/18/2014 10:35 PM, BABITHA REDDY wrote:
> Hi,
> The following output i got, for vector converted to raster and for
> that raster i used r.info <http://r.info>
> r.info <http://r.info> -g -e map=vtr at battu
> north=5373915
> south=5135385
> east=642315
> west=407385
> nsres=30
> ewres=30
> rows=7951
> cols=7831
> cells=62264281
> datatype=DCELL
> title="Categories (vtr)"
> units="none"
> vertical_datum="none"
> source1="Vector Map:
> RGP_Before_2014_Wagner_s_80_E_of_Hwy_80_E_of_HWY_20_2013_Harvesting_Corn_Harvest_Corn at battu"
> source2="Original scale from vector map: 1:1"
> description="generated by v.to.rast"
> timestamp="none"
> On Thu, Dec 18, 2014 at 1:29 PM, Micha Silver <micha at arava.co.il
> <mailto:micha at arava.co.il>> wrote:
>     The important information is the region settings. Please post the
>     output of g.region -p.
>     Also r.info <http://r.info> on the resulting raster will help.
>     Also note, as Tom mentioned, that you probably want to
>     *interpolate* a continuous raster from the point values.
>     Converting a point vector directly to a raster with v.to.rast will
>     give you individual raster pixels with some value, and all the
>     rest of the raster pixels with zero (or null).
>     On 12/18/2014 09:10 PM, BABITHA REDDY wrote:
>>     Hi,
>>     I have to convert the vector(point) data into raster, I imported
>>     point data into the GRASS and then used v.to.rast command to
>>     convert vector to raster map, but the same problem: nothing is
>>     displayed on the display, and query data is giving a value of
>>     zero in the map display.
>>     If it is a problem with projection and region, please help me to
>>     resolve this.
>>     the point data's metadata is :
>>      | Mapset:          battu                                   |
>>      | Location:        RedRiverValley
>>      | Database:  /home/shared/research/GRASSDATA             |
>>      | Title:                                   |
>>      | Map scale:       1:1                                   |
>>      | Name of creator: battu                                   |
>>      | Organization:                                    |
>>      | Source date:     Mon Dec 15 16:18:26 2014
>>      | Timestamp (first layer): none                                    |
>>      | Map format:      native                                    |
>>      |   Type of map: vector (level: 2)
>>      |   Number of points:       10182   Number of centroids:  0
>>      |   Number of lines:        0   Number of boundaries: 0          |
>>      |   Number of areas:        0   Number of islands:    0          |
>>      |   Map is 3D:              No                                   |
>>      |   Number of dblinks:      1                                    |
>>      |   Projection: UTM (zone 14)                                    |
>>      |               N:       46.98666723    S:       46.97957943
>>      |               E:      -98.65789266    W:      -98.66294363
>>      |   Digitization threshold: 0                                    |
>>      |   Comment:                                   |
>>     and
>>     g.proj -p gives me the following:
>>     -PROJ_INFO-------------------------------------------------
>>     name       : Universal Transverse Mercator
>>     proj       : utm
>>     datum      : wgs84
>>     ellps      : wgs84
>>     zone       : 14
>>     no_defs    : defined
>>     -PROJ_UNITS------------------------------------------------
>>     unit       : metre
>>     units      : metres
>>     meters     : 1
>>     Could please anyone help me solve this issue. I need to generate
>>     raster maps from given vector(point) data.
>>     Thanks
>>     On Tue, Dec 9, 2014 at 2:09 PM, Thomas Adams <tea3rd at gmail.com
>>     <mailto:tea3rd at gmail.com>> wrote:
>>         Babitha,
>>         How did you do your vector point to raster interpolation;
>>         v.surf.bspline; v.surf.idw; v.krige,…? Did you use d.rast to
>>         display the raster map; do you have a MASK set; is your GRASS
>>         Region set correctly?
>>         Knowing your steps in more detail would be helpful…
>>         Tom
>>         On Tue, Dec 9, 2014 at 12:53 PM, BABITHA REDDY
>>         <reddybabitha at gmail.com <mailto:reddybabitha at gmail.com>> wrote:
>>             Hi All,
>>             After converting a shape file(point) into raster using
>>             GRASS7, it is not displaying  the converted raster map.
>>             When i query the raster map it is displaying the value as
>>             0, even though there are values.
>>             Please help how to solve this problem
>>             Thanks
>>             _______________________________________________
>>             grass-user mailing list
>>             grass-user at lists.osgeo.org
>>             <mailto:grass-user at lists.osgeo.org>
>>             http://lists.osgeo.org/mailman/listinfo/grass-user
>>     This mail was received via Mail-SeCure System.
>>     grass-user at lists.osgeo.org  <mailto:grass-user at lists.osgeo.org>
