[GRASS-user] installation of grass 7 unknown-linux binaries
José Anderson joseandersonbatista at gmail.com
Tue Feb 4 08:41:20 PST 2014
Hamish,
I found the GUI package in the repository with the name 'grass70-gui'
instead of 'grass-gui', as shown in the
http://packages.ubuntu.com/search?keywords=grass
Also, the grass70.desktop, the command name should be 'grass70'
instead of 'grass7'.
I'll keep on testing it.
2014-02-04 José Anderson <joseandersonbatista at gmail.com>:
> J, H,
> the long term supported (LTS) ubuntu up-to-date is 12.04, but
> grass-gui is not available to it.
> By the way, other grass-gui release number is 6.4 instead of 7.0. Is
> that correct to grass 7?
> Should 'grass-gui_6.4.2-2build1_amd64.deb' work in ubuntu 12.04?
> 2014-02-03 Hamish <hamish_b at yahoo.com>:
>> is the grass-gui package installed?
>> if so, check files with:
>> $ dpkg -L grass-gui
>> Hamish
>>> On Tuesday, February 4, 2014 9:56 AM, José Anderson <joseandersonbatista at gmail.com> wrote:
>>> >T hanks Hamish,
>>> think that binaries were not available yet when I reached the
>>> repository first time.
>>> Well, anyways, it looks like no GUI is present. The following error
>>> raises, since (and I checked) no /usr/lib/grass70/etc/gui directory
>>> was created.
>>> python: can't open file
>>> '/usr/lib/grass70/etc/gui/wxpython/gis_set.py': [Errno 2] No such file
>>> or directory
>>> Nevertheless, I feel it is getting close...
>>>>  José wrote:
>>>>>>   thanks for your quick reply.
>>>>>>   My ubuntu is 64bits in fact.
>>>>  Markus N:
>>>>>  I have no Ubuntu, so I cannot say much here. But we build the snapshot
>>>>>  binaries in a Debian box.
>>>>>>   Now I have to build wxpython yet (hope 3.0.0 is supported)
>>>>>>   This tutorial seams ok. http://wiki.wxpython.org/CheckInstall.
>>>>>  Why can't you simply use the wxpython offered by ubuntu?
>>>>  Hi,
>>>>  there are pre-made grass7 packages for ubuntu already built, (albeit
>>>>  a few weeks out of date)
>>>>  https://launchpad.net/~grass/+archive/grass-devel
>>>>  http://grasswiki.osgeo.org/wiki/Ubuntu_Packaging
>>>>  but I would always encourage users who wish to try development versions
>>>>  of code to build GRASS from source themselves, it's not so bad; these
>>>>  instructions should work:
>>>>  https://trac.osgeo.org/grass/browser/grass/trunk/debian/README.debian
>>>>  http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
>>>>  regards,
>>>>  Hamish
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
