[GRASS-user] SRTM r.watershed at multiple scales
Michel Wortmann wortmann at pik-potsdam.de
Wed Feb 19 05:56:38 PST 2014
Markus,
last year you asked me whether the r.watershed output is not aligned to
the r.water.outlet output in GRASS7 (s.b.). Ie. it leaves small areas
out. Back then, I wasnt using GRASS7, but I can confirm now that it
still does it and it is still rather annoying. Have you ever heard of
the reasons or attempted to fix this?
Thanks,
Michel
On 08/26/2013 03:25 PM, Markus Neteler wrote:
> On 08/22/2013 08:52 AM, Markus Neteler wrote:
>> >>Hi Michel,
>> >>On Wed, Aug 21, 2013 at 1:18 PM, Michel Wortmann
>> >><wortmann at pik-potsdam.de>  wrote:
>>> >>>As the r.watershed algorithm often leaves small areas at the edges
>>> >>>uncovered, you'll have to fill those before or after patching, otherwise
>>> >>>you'll have holes in your subbasin map.
>> >>... just curious: does this happen still in the latest GRASS 7 version?
>> >>Markus
