[GRASS-user] SRTM r.watershed at multiple scales
jencor808 jencor808 at gmail.com
Wed Feb 19 08:22:45 PST 2014
I've been having the same problem. I have seen figures illustrating the
issue in riparian areas, where the watersheds 'end', leaving holes where
perhaps very small watersheds should be delineated along rivers/streams
instead. Personally, I am having this issue along coastlines, but its the
same as in the riparian case. I can't even fill the holes with a tiny
threshold and I'm hesitant to make up my own watersheds at the coast.
Is there a way to provide a bounding line (ie. coastline) and wall-to-wall
watersheds at a given scale are delineated within that area?
On Wednesday, February 19, 2014, Thomas Adams-2 [via OSGeo.org] <
ml-node+s1560n5104742h59 at n6.nabble.com> wrote:
> I've been using GRASS 7 for this and have not seen a problem -- I hope I'm
> not overlooking the issue. Michel, can you provide an image that shows this?
> Thanks,
> Tom
> On Wednesday, February 19, 2014, Michel Wortmann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5104742&i=0>>
> wrote:
>> Markus,
>> last year you asked me whether the r.watershed output is not aligned to
>> the r.water.outlet output in GRASS7 (s.b.). Ie. it leaves small areas out.
>> Back then, I wasnt using GRASS7, but I can confirm now that it still does
>> it and it is still rather annoying. Have you ever heard of the reasons or
>> attempted to fix this?
>> Thanks,
>> Michel
>> On 08/26/2013 03:25 PM, Markus Neteler wrote:
>>> On 08/22/2013 08:52 AM, Markus Neteler wrote:
>>>> >>Hi Michel,
>>>> >>On Wed, Aug 21, 2013 at 1:18 PM, Michel Wortmann
>>>> >><[hidden email]<http://user/SendEmail.jtp?type=node&node=5104742&i=1>>
>>>>  wrote:
>>>>> >>>As the r.watershed algorithm often leaves small areas at the edges
>>>>> >>>uncovered, you'll have to fill those before or after patching,
>>>>> otherwise
>>>>> >>>you'll have holes in your subbasin map.
>>>> >>... just curious: does this happen still in the latest GRASS 7
>>>> version?
>>>> >>Markus
>> grass-user mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5104742&i=2>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Thomas E Adams, III
> 718 McBurney Drive
> Lebanon, OH 45036
> 1 (513) 739-9512 (cell)
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5104742&i=3>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/SRTM-r-watershed-at-multiple-scales-tp5072885p5104742.html
>  To unsubscribe from SRTM r.watershed at multiple scales, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5072885&code=amVuY29yODA4QGdtYWlsLmNvbXw1MDcyODg1fDk0ODk1MjU3NA==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Jennifer M. Corcoran, PhD
NASA Postdoctoral Program Fellow
Jet Propulsion Laboratory
4800 Oak Grove Drive
La Cañada Flintridge, CA 91011
alt email: Jennifer.M.Corcoran at jpl.nasa.gov
website: www.jennifermcorcoran.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/SRTM-r-watershed-at-multiple-scales-tp5072885p5104751.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140219/63e81b84/attachment.html>
