[GRASS-user] Kyngesburye GRASS on Mavericks, command line access
Michael Barton Michael.Barton at asu.edu
Thu Jan 9 09:49:38 PST 2014
If you run this from the GRASS terminal, it should find GRASS without any issue, unless it has hard coded a call to GRASS commands in the /usr/bin folder.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jan 9, 2014, at 8:09 AM, <grass-user-request at lists.osgeo.org<mailto:grass-user-request at lists.osgeo.org>> <grass-user-request at lists.osgeo.org<mailto:grass-user-request at lists.osgeo.org>> wrote:
From: William Kyngesburye <woklist at kyngchaos.com<mailto:woklist at kyngchaos.com>>
Subject: Re: [GRASS-user] Kyngesburye GRASS on Mavericks, command line access
Date: January 9, 2014 at 7:37:07 AM MST
To: Dheeraj Chand <dheeraj at dheerajchand.com<mailto:dheeraj at dheerajchand.com>>
Cc: <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com<mailto:kyngchaos at kyngchaos.com>>
I think there is info in the installed readme.  You can make a symlink to the grass.sh in the app in /usr/local/bin.
On Jan 8, 2014, at 11:48 PM, Dheeraj Chand wrote:
Hey, all! I'm using William Kyngesburye's GRASS for Mac OS X Mavericks. It seems to install as a traditional Mac application, which opens and has a Terminal that can be used. It doesn't seem to install to the bin, the way that the Linux versions do.  Here's my situation. I have a script that we can call "geographizer.sh" that contains lots and lots of instructions for GRASS that was written by a colleague. This script needs to be executed at the end of a complex Python script, with the last command being, essentially, "Now, run this bash script!" My question is whether or not I can, so to speak, use the WK GRASS as if it were installed in the bin, as it is in Ubuntu.  If so, can someone guide me through setting that up?
Best,
-dx
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140109/747ea29c/attachment-0001.html>
