[GRASS-user] v.patch errors using 7.1 svn
Anna Petrášová kratochanna at gmail.com
Wed Jun 11 09:45:01 PDT 2014
Hi John,
these are not error messages, just some recommendations which are
apparently confusing and don't apply to your situation.
Anna
On Wed, Jun 11, 2014 at 12:18 PM, John Wall <jwall at ncsu.edu> wrote:
> Hello,
> I am attempting to use v.patch in GRASS 7.1 svn. After running v.patch I
> get the following error:
> Intersections at borders will have to be snapped
> Lines common between files will have to be edited
> The header information also may have to be edited
> v.patch is being run on the results of v.in.lidar which appear to be
> imported correctly. The results of running v.patch appear correct as well.
> I simply want to make sure that these errors will not be an issue during
> further analysis.
> From what I can find on earlier posts to this mailing list for GRASS 5 & 6
> [e.g. 1 ], it appears v.clean tool=snap is recommended. Is this still the
> case?
> -J Wall
> [ 1 ] http://lists.osgeo.org/pipermail/grass-dev/2006-July/024440.html
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140611/1a184ab2/attachment.html>
