[GRASS-user] Usage of r.sim.water (error - no ouput grid created)
Mag. Andreas Reithofer - Ingenieurbüro Humer reithofer at ib-humer.at
Wed Mar 5 09:18:33 PST 2014
Dear GRASS Users,
Being quite a newbie to GRASS, I have the task to model overlandflow via GIS-tools for simulating flash floods. This lead me to r.sim.water, which I tried to run for a ~5km² area with a 25m raster dgm, but with no success until now.
I have a grid with the DEM, two grids with the first partial derivative x/y, a grid with manning´s coeff, a grid with effective rainfall and that´s it - should work, shouldn´t it?
Do you have a hint for me, why this does not work in my case?
(see parameters in png, log in txt)
THANK YOU!!!
Regards,
Andreas
Mit freundlichen Grüßen
Akad. Geoinformatiker
email: Reithofer at ib-humer.at
Tel.: 07732-4146-35
________________________________________________________________________
Ingenieurbüro für Kulturtechnik und Wasserwirtschaft, Consulting Engineer
Feld 16, 4682 Geboltskirchen, Austria
Tel.: 07732-4146, Fax.: DW - 22
www.ib-humer.at
office at ib-humer.at
Fb.Nr.: FN 312673 p
g.proj -c proj4="+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks.tif" band=1 output=tmp13940388217816 --overwrite -o
r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks_1st_order_dx.tif" band=1 output=tmp13940388217817 --overwrite -o
r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks_1st_order_dy.tif" band=1 output=tmp13940388217818 --overwrite -o
r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\BNS_60min.tif" band=1 output=tmp13940388217819 --overwrite -o
r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\dummygrid_null.tif" band=1 output=tmp13940388217820 --overwrite -o
r.external input="K:\Proj_2012\12092_switchOn\work_temp\CLC2006\Raster_100m\m_coeff_25m.tif" band=1 output=tmp13940388217821 --overwrite -o
g.region n=2806700.0 s=2803000.0 e=4636212.5 w=4633100.0 res=25.0
r.sim.water elevin=tmp13940388217816 dxin=tmp13940388217817 dyin=tmp13940388217818 rain=tmp13940388217819 infil=tmp13940388217820 manin=tmp13940388217821 traps=tmp13940388217820 niter="15" outiter="15" diffc="0.8" hmax="0.3" halpha="4.0" hbeta="0.5" -t depth=depthd5667d4a1b7a4136a850a17a410fbc54 disch=dischd5667d4a1b7a4136a850a17a410fbc54 err=errd5667d4a1b7a4136a850a17a410fbc54 --overwrite
g.region rast=depthd5667d4a1b7a4136a850a17a410fbc54
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=depthd5667d4a1b7a4136a850a17a410fbc54 output="K:/Proj_2012/12092_switchOn/work_temp/SAGA_DEM_EU/_output.tif"
g.region rast=dischd5667d4a1b7a4136a850a17a410fbc54
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=dischd5667d4a1b7a4136a850a17a410fbc54 output="C:\Users\user_x\AppData\Local\Temp\processing\2219fb8bc6784cd0903ee0a0f3004e47\disch.tif"
g.region rast=errd5667d4a1b7a4136a850a17a410fbc54
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=errd5667d4a1b7a4136a850a17a410fbc54 output="C:\Users\user_x\AppData\Local\Temp\processing\b7920c941552441f9b2cba64799bd835\err.tif"
C:\PROGRA~1\QGISDU~1\bin>set HOME=C:\Users\user_x
C:\PROGRA~1\QGISDU~1\bin>set GISRC=C:\Users\user_x\.qgis2\\processing\processing.gisrc
C:\PROGRA~1\QGISDU~1\bin>set GRASS_SH=C:/PROGRA~1/QGISDU~1/apps\msys\bin\sh.exe
C:\PROGRA~1\QGISDU~1\bin>set PATH=C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>set WINGISBASE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~1\QGISDU~1\bin>set GISBASE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~1\QGISDU~1\bin>set GRASS_PROJSHARE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\share\proj
C:\PROGRA~1\QGISDU~1\bin>set GRASS_MESSAGE_FORMAT=gui
C:\PROGRA~1\QGISDU~1\bin>if "" == "" set PATH=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>if not "" == "" set PATH=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>set GRASS_VERSION=6.4.0
C:\PROGRA~1\QGISDU~1\bin>if not "" == "" goto langset
C:\PROGRA~1\QGISDU~1\bin>FOR /F "usebackq delims==" %i IN (`"C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\winlocale"`) DO @set LANG=%i
C:\PROGRA~1\QGISDU~1\bin>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
C:\PROGRA~1\QGISDU~1\bin>set PYTHONPATH=C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/etc/python;;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\python;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\wxpython\n
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="MAPSET=PERMANENT"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="LOCATION=temp_location"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="LOCATION_NAME=temp_location"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="GISDBASE=C:\Users\user_x\AppData\Local\Temp\processing\grassdata"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="GRASS_GUI=text"
C:\PROGRA~1\QGISDU~1\bin>g.proj -c proj4="+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000 +y_0=3210000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
GRASS_INFO_MESSAGE(4204,1): Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben, sollten Sie `g.region -d` in jedem ausführen, um die Einstellungen von der Standardregion zu übernehmen.
GRASS_INFO_END(4204,1)
GRASS_INFO_MESSAGE(4204,2): Projektionsinformationen aktualisiert
GRASS_INFO_END(4204,2)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks.tif" band=1 output=tmp13940388217816 --overwrite -o
GRASS_INFO_WARNING(2564,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(2564,1)
GRASS_INFO_MESSAGE(2564,2): Importing band 1 of 1...
GRASS_INFO_END(2564,2)
GRASS_INFO_MESSAGE(2564,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(2564,3)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks_1st_order_dx.tif" band=1 output=tmp13940388217817 --overwrite -o
GRASS_INFO_WARNING(4232,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(4232,1)
GRASS_INFO_MESSAGE(4232,2): Importing band 1 of 1...
GRASS_INFO_END(4232,2)
GRASS_INFO_MESSAGE(4232,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(4232,3)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\DEM_leonding_nosinks_1st_order_dy.tif" band=1 output=tmp13940388217818 --overwrite -o
GRASS_INFO_WARNING(7000,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(7000,1)
GRASS_INFO_MESSAGE(7000,2): Importing band 1 of 1...
GRASS_INFO_END(7000,2)
GRASS_INFO_MESSAGE(7000,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(7000,3)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\BNS_60min.tif" band=1 output=tmp13940388217819 --overwrite -o
GRASS_INFO_WARNING(6372,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(6372,1)
GRASS_INFO_MESSAGE(6372,2): Importing band 1 of 1...
GRASS_INFO_END(6372,2)
GRASS_INFO_MESSAGE(6372,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(6372,3)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\SAGA_DEM_EU\dummygrid_null.tif" band=1 output=tmp13940388217820 --overwrite -o
GRASS_INFO_WARNING(5760,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(5760,1)
GRASS_INFO_MESSAGE(5760,2): Importing band 1 of 1...
GRASS_INFO_END(5760,2)
GRASS_INFO_MESSAGE(5760,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(5760,3)
C:\PROGRA~1\QGISDU~1\bin>r.external input="K:\Proj_2012\12092_switchOn\work_temp\CLC2006\Raster_100m\m_coeff_25m.tif" band=1 output=tmp13940388217821 --overwrite -o
GRASS_INFO_WARNING(6596,1): Übersteuere die Überprüfung der Projektion.
GRASS_INFO_END(6596,1)
GRASS_INFO_MESSAGE(6596,2): Importing band 1 of 1...
GRASS_INFO_END(6596,2)
GRASS_INFO_MESSAGE(6596,3): Link zur Rasterkarte erzeugt
GRASS_INFO_END(6596,3)
C:\PROGRA~1\QGISDU~1\bin>g.region n=2806700.0 s=2803000.0 e=4636212.5 w=4633100.0 res=25.0
C:\PROGRA~1\QGISDU~1\bin>r.sim.water elevin=tmp13940388217816 dxin=tmp13940388217817 dyin=tmp13940388217818 rain=tmp13940388217819 infil=tmp13940388217820 manin=tmp13940388217821 traps=tmp13940388217820 niter="15" outiter="15" diffc="0.8" hmax="0.3" halpha="4.0" hbeta="0.5" -t depth=depthd5667d4a1b7a4136a850a17a410fbc54 disch=dischd5667d4a1b7a4136a850a17a410fbc54 err=errd5667d4a1b7a4136a850a17a410fbc54 --overwrite
GRASS_INFO_MESSAGE(6308,1): Standard nwalk=37000, rwalk=37000.000000
GRASS_INFO_END(6308,1)
GRASS_INFO_MESSAGE(6308,2): Min elevation = 273.88 m
GRASS_INFO_MESSAGE(6308,2): Max elevation = 506.77 m
GRASS_INFO_END(6308,2)
GRASS_INFO_MESSAGE(6308,3): Mean Source Rate (rainf. excess or sediment) = 0.000009 m/s or kg/m2s
GRASS_INFO_END(6308,3)
GRASS_INFO_MESSAGE(6308,4): Mean flow velocity = 2.819856 m/s
GRASS_INFO_END(6308,4)
GRASS_INFO_MESSAGE(6308,5): Mean Mannings = 0.081520
GRASS_INFO_END(6308,5)
GRASS_INFO_MESSAGE(6308,6): Number of iterations = 101 cells
GRASS_INFO_END(6308,6)
GRASS_INFO_MESSAGE(6308,7): Time step = 2.21 s
GRASS_INFO_END(6308,7)
C:\PROGRA~1\QGISDU~1\bin>g.region rast=depthd5667d4a1b7a4136a850a17a410fbc54
GRASS_INFO_ERROR(6300,1): Rasterkarte konnte nicht gefunden werden.
GRASS_INFO_END(6300,1)
C:\PROGRA~1\QGISDU~1\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=depthd5667d4a1b7a4136a850a17a410fbc54 output="K:/Proj_2012/12092_switchOn/work_temp/SAGA_DEM_EU/_output.tif"
GRASS_INFO_ERROR(7036,1): Rasterkarte oder Gruppe nicht gefunden.
GRASS_INFO_END(7036,1)
C:\PROGRA~1\QGISDU~1\bin>g.region rast=dischd5667d4a1b7a4136a850a17a410fbc54
GRASS_INFO_ERROR(6508,1): Rasterkarte konnte nicht gefunden werden.
GRASS_INFO_END(6508,1)
C:\PROGRA~1\QGISDU~1\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=dischd5667d4a1b7a4136a850a17a410fbc54 output="C:\Users\user_x\AppData\Local\Temp\processing\2219fb8bc6784cd0903ee0a0f3004e47\disch.tif"
GRASS_INFO_ERROR(2612,1): Rasterkarte oder Gruppe nicht gefunden.
GRASS_INFO_END(2612,1)
C:\PROGRA~1\QGISDU~1\bin>g.region rast=errd5667d4a1b7a4136a850a17a410fbc54
GRASS_INFO_ERROR(1436,1): Rasterkarte konnte nicht gefunden werden.
GRASS_INFO_END(1436,1)
C:\PROGRA~1\QGISDU~1\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=errd5667d4a1b7a4136a850a17a410fbc54 output="C:\Users\user_x\AppData\Local\Temp\processing\b7920c941552441f9b2cba64799bd835\err.tif"
GRASS_INFO_ERROR(2244,1): Rasterkarte oder Gruppe nicht gefunden.
GRASS_INFO_END(2244,1)
C:\PROGRA~1\QGISDU~1\bin>exit
Converting outputs
Loading resulting layers
Algorithm r.sim.water - Overland flow hydrologic simulation using path sampling method (SIMWE). finished
-------------- n?chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140305/5537b43f/attachment-0001.html>
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : image001.gif
Dateityp    : image/gif
Dateigr??e  : 5601 bytes
Beschreibung: nicht verf?gbar
URL         : <http://lists.osgeo.org/pipermail/grass-user/attachments/20140305/5537b43f/attachment-0001.gif>
Ein eingebundener Text mit undefiniertem Zeichensatz wurde abgetrennt.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140305/5537b43f/attachment-0001.txt>
Dateiname   : parameters.png
Dateityp    : image/png
Dateigr??e  : 73470 bytes
URL         : <http://lists.osgeo.org/pipermail/grass-user/attachments/20140305/5537b43f/attachment-0001.png>
