[GRASS-user] v.net.allpairs on PostgreSQL
Patrick S. patrick_GIS at gmx.ch
Wed Mar 12 02:40:57 PDT 2014
Thanks, Markus.
In that case it would be of advantage to remove this function.
However, before I go for GRASS 7 (which will be harder to host on our
Server): The module v.net.allpairs in GRASS 7.0 demands to keep points
and lines on different layers, which did not work for me when using
PostgreSQL as database. Did I do something wrong, or is this a
limitation of GRASS/PostgreSQL?
Patrick
But does
On 03/11/2014 10:39 PM, Markus Neteler wrote:
> On Tue, Mar 11, 2014 at 9:01 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> v.net.allpairs does not work properly in GRASS 6.
> Should we drop it from G6?
>> You need to use GRASS 7 if you want to use this module.
> (we'll hopefully package the tech preview release at the Vienna code
> sprint but you can get it from here:
> http://grass.osgeo.org/grass7/
> best
> markusN
