[GRASS-user] Building -7.0 Fails
Rich Shepard rshepard at appl-ecosys.com
Fri Mar 14 12:13:58 PDT 2014
   Running Slackware-14.1 here with Python-2.7.5 and wxPython-2.8.12.1. I
just decided to install -7svn in addition to -6.5svn. The latter continues
to build error-free; the latter fails:
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
  /dev/null | grep -v '</body>\|</html>' > g.gui.timeline.tmp.html
   File
"/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-linux-gnu/scripts/g.gui.timeline",
line 39, in <module>
     import  wx
ImportError: No module named wx
make[1]: *** [g.gui.timeline.tmp.html] Error 1
rm g.gui.timeline.tmp.html
make[1]: Leaving directory
/home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline'
make: *** [guiscript] Error 2
   There is no error log in the base directory.
   All suggestions on why wx fails to import are certainly welcome.
Rich
Richard B. Shepard, Ph.D.          |      Have knowledge, will travel.
Applied Ecosystem Services, Inc.   |
www.appl-ecosys.com      Voice: 503-667-4517         Fax: 503-667-8863
