[GRASS-user] Building -7.0 Fails
Anna Petrášová kratochanna at gmail.com
Sat Mar 15 05:52:51 PDT 2014
On Fri, Mar 14, 2014 at 3:13 PM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
>   Running Slackware-14.1 here with Python-2.7.5 and wxPython-2.8.12.1. I
> just decided to install -7svn in addition to -6.5svn. The latter continues
> to build error-free; the latter fails:
> /home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
>  /dev/null | grep -v '</body>\|</html>' > g.gui.timeline.tmp.html
> Traceback (most recent call last):
>   File
> "/home/rshepard/GIS/GRASS/grass-7.0svn/dist.i686-pc-
> linux-gnu/scripts/g.gui.timeline",
> line 39, in <module>
>     import  wx
> ImportError: No module named wx
> make[1]: *** [g.gui.timeline.tmp.html] Error 1
> rm g.gui.timeline.tmp.html
> make[1]: Leaving directory
> /home/rshepard/GIS/GRASS/grass-7.0svn/gui/wxpython/timeline'
> make: *** [guiscript] Error 2
>   There is no error log in the base directory.
>   All suggestions on why wx fails to import are certainly welcome.
only g.gui.timeline does not compile? Or also other g.gui.* modules
(g.gui.animation, g.gui.rlisetup,...)? Anyway have you tried to launch
grass gui and try to run g.gui.timeline?. This compilation error (if it
appears) is usually harmless but I don't understand why it appears
(something wrong with the  building environment, not your fault).
Anna
> Rich
> Richard B. Shepard, Ph.D.          |      Have knowledge, will travel.
> Applied Ecosystem Services, Inc.   |
> www.appl-ecosys.com      Voice: 503-667-4517         Fax: 503-667-8863
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140315/a6fe6abb/attachment.html>
