[GRASS-user] Elevation differences between endpoints of least cost	paths
    MacQueen, Don
    macqueen1 at llnl.gov
    Fri Mar 21 15:47:32 PDT 2014
I'm stating with a DEM (named FD).
First I find streams:
  r.watershed elevation=FD stream=stream
  r.thin input=stream output=stream.thin
Then, for each point on the DEM, I need
 The distance to the nearest point in a stream
 The elevation difference to the stream point
I can get the distance by gollowing the example "Computing a distance map"
in Neteler & Mitasova's GRASS book:
  r.mapcalc area.one=1
  r.cost -k input=area.one output=dtv start_rast=stream.thin
So far so good, and the results make sense
But I would very much appreciate suggestions for the elevation difference.
I have been looking at various r.* routines, such as r.drain, but haven't
yet found a solution. I have very little experience with raster analysis.
(and in fact, I'm using the R package spgrass6 to manage the above steps)
Thanks
-Don
Don MacQueen
Lawrence Livermore National Laboratory
7000 East Ave., L-627
Livermore, CA 94550
925-423-1062
