[GRASS-user] the map does not render
Juan Carlos Torres jctorres at ugr.es
Tue Mar 25 08:17:08 PDT 2014
Dear Nikas
Try to run
g.region rast=*_ninety
_*before d.rast. If it does not work, give us the result of
g.region -p
best regards
Juan Carlos Torres
El 25/03/14 11:49, Nikas Nikolas escribió:
>  Dear all, please give some advice.
> The map doesn't render, but when I move the cursor the coordinates are
> changing. When I the "set computational regions" I get the
> *_Command 'd.rast map=ninety en chdet' failed_*
> The display projection command  gives this result
> *g.proj -p*
> -PROJ_INFO-------------------------------------------------
> proj       : tmerc
> ellps      : grs80
> lat_0      : 0
> lon_0      : 24
> k          : 0.9996
> x_0        : 500000
> y_0        : 0
> towgs84    : -199.87,74.79,246.62,0,0,0,0
> no_defs    : defined
> -PROJ_UNITS------------------------------------------------
> unit       : metre
> units      : metres
> meters     : 1
> and when I choose metadata I get all the information
> *r.info <http://r.info> map*=ninety en chdet
>  | Layer:    ninety en chdet                   Date: Thu Mar 06 17:22:58
> 2014
>  | Mapset:   chdet                          Login of Creator:
> gounaridis.d
>  | Location: newLocation
>  | DataBase: H:\GRASSDATA
>  | Title:     ( ninety )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 4
>  |   Data Type:    CELL
>  |   Rows:         584
>  |   Columns:      632
>  |   Total Cells:  369088
>  |        Projection: Transverse Mercator
>  |            N: 4204475.77974522    S: 4186371.77974522 Res:    31
>  |            E: 502018.59283775    W: 482426.59283775   Res:    31
>  |   Range of data:    min = 1  max = 4
>  |   Data Description:
>  |    generated by r.in.gdal
>  |   Comments:
>  |    r.in.gdal -o
> input="D:\mathima1\master\SIGIS\SIGIS\LUCC\DATA\sigisas\
>  |    k1\cl1990\hdr.adf" output="ninety"
> *System Info *
> GRASS version: 6.4.3
> GRASS SVN Revision:
> GIS Library Revision: 50937 (2012-02-25)
> GDAL/OGR: 1.10.1
> PROJ4: Rel. 4.8.0, 6 March 2012
> Python: 2.7.5
> wxPython: 2.8.12.1
> Platform: Windows-8-6.2.9200 (OSGeo4W)
> Thank you for your time
> NN
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
Juan Carlos Torres                      | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual         | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos |       (+34) 958 249 307
ETS. Ing. Informatica                   |     interno ugr  71 260
Univ. de Granada                        | FAX: (+34) 958 243 179
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140325/71105873/attachment.html>
