[GRASS-user] r.out.gdal Python code
Nikos Alexandris nik at nikosalexandris.net
Thu Nov 6 10:41:41 PST 2014
Adam Hoffritz wrote:
>> Hello all,
>> I'm having a problem with my r.out.gdal python code. This is the
>> code (run
>> from python shell in Grass7)
>> grass.run_command('r.outgdal', input=items,
>> output='G:/Lokaverkefni/blettagreining/tifs/items[:-10]
Nikos Alexandris wrote:
> I have no idea about working under windows and how to define paths.
> But, the "." is missing from your r.out.gdal command above (in case
> you copy-pasted).
As well, the r.out.gdal command accepts a single input or group which
it will export. Given you need to export many "items", as the part
"input=items" in your command above implies, the way to do it, should
likely be to loop over a list of items.
You might want to post a bigger part of your code.
Nikos
