[GRASS-user] v.rast.stats by other column instead of 'cat'
Javier Martínez-López javi.martinez.lopez at gmail.com
Fri Nov 7 01:36:55 PST 2014
I will try... thanks!
On Fri, Nov 7, 2014 at 10:31 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 07/11/14 10:25, Javier Martínez-López wrote:
>> Dear all,
>> is it possible to use v.rast.stats or a similar function to compute
>> univariate statistics from a raster map for each category present in a
>> column of a vector map? As far as I know v.rast.stats only allow to do
>> it by 'cat'.
> I think this is true, but you can use v.reclass to create a vector map
> according to your new categories and the run v.what.rast with that...
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
