[GRASS-user] [GRASS-dev] wxGUI raster digitizer available
Paulo van Breugel p.vanbreugel at gmail.com
Thu Nov 20 01:37:03 PST 2014
Hi Anna
This is great, thanks! This is going to be a real time saver.
I am having trouble however running it. I seems to work fine except that I
can't save the edits. To leave the editing session, I have to select no
when asked to save the work.
Not sure if the below helps, but in the terminal I get the message:
GRASS_INFO_ERROR(30864,1): Raster map <pnv_malawi2_ag2_backupcopy_30725>
not found
GRASS_INFO_END(30864,1)
>From the command console:
Exception in thread Thread-8:
  File "/usr/lib/python2.7/threading.py", line 810, in
__bootstrap_inner
    self.run()
  File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/core/gt
hread.py", line 94, in run
    ret = vars()['callable'](*args, **kwds)
  File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/rdigit/
controller.py", line 467, in _exportRaster
    output=self._editedRaster, overwrite=True, quiet=True)
  File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
ipt/core.py", line 373, in run_command
    return handle_errors(returncode, returncode, args,
kwargs)
ipt/core.py", line 308, in handle_errors
    returncode=returncode)
CalledModuleError: Module run None ['r.patch', '--o', '--q',
u'input=x47731795,pnv_malawi2_ag2_backupcopy_30725',
u'output=pnv_malawi2_ag2 at vegetation'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
On Wed, Nov 19, 2014 at 11:56 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Nov 19, 2014 at 3:31 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi Anna,
>> On Tue, Nov 18, 2014 at 5:19 AM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> > Hi all,
>> > I added raster digitizer in r62792 in trunk.
>> what a great job!
>> If you didn't find it: it is in the "Map Display" windows, then
>> selector on the right side (2D/3D/Vector digitizer/Raster digitizer).
> Once everything works, I will probably make a short video tutorial.
>> > You are welcome to test it and
>> > report bugs/enhancements.
>> > It currently allows to draw areas, lines and points and specify width to
>> > buffer individual features. We can discuss some changes in gui
>> interface and
>> > behavior if you find the current one intuitive.  There is still a lot to
>> > improve especially in the drawing part (needs some refactoring of the
>> old
>> > drawing code).
>> One general thing I found (also valid for the vector digitizer): I
>> wonder where to put a message what the mouse buttons mean.
>> Maybe in the status bar at bottom of the display/digitizer window?
>> > Features:
>> > - draw area, line, point
>> ... works.
>> > - specify buffer width for individual features to create for example
>> > circles, roads of certain width...
>> ... maybe rename from "Width" to "Buffer width"? Otherwise it could be
>> confused with the drawing line width.
> There is not much space in toolbar..., especially if we in the future add
> more items (settings, label editing for example). What about just 'Buffer'?
> Currently the width is the width of the buffered line/diameter of the point
> (circle), which means 2 x buffer distance, so if we change it to buffer,
> then the value should be half of the line width?
>> > - specify background map
>> ... works (maybe have a button to optionally take computational region
>> from that map?)
> Yes possibly, I am not sure about the region in general, if there should
> be any special handling.
>> > - simple undo
>> > - save button to save results during drawing
>> here I got an issue somewhere:
>> Exception in thread Thread-4:
>>   File "/usr/lib64/python2.7/threading.py", line 811, in
>> __bootstrap_inner
>>     self.run()
>>   File "/home/neteler/software/grass71/dist.x86_64-unknown-
>> linux-gnu/gui/wxpython/core/gthread.py", line 94, in run
>> linux-gnu/gui/wxpython/rdigit/controller.py", line 432, in
>> _exportRaster
>>     if item.GetPropertyVal('widthValue') and \
>> linux-gnu/gui/wxpython/mapwin/graphics.py", line 439, in
>> GetPropertyVal
>>     raise KeyError(_("Property does not exist: %s") %
>> (propName))
>> KeyError: 'Property does not exist: widthValue'
> it normally works... Does this happen every time?
>> > - keeps drawing order in the output raster map
>> > - change color of drawing
>> > - doesn't block gui when exporting raster (which can take some time)
>> Nice!
>> > Does not support (yet?):
>> > - adding labels
>> > - interactive setting color of raster cells (not planned, there are
>> other tools)
>> > - vector export/import
>> > Known issues:
>> > - r.in.poly supports only CELL (I just realized that, this must be
>> changed)
>> (meanwhile you changed that already, thanks)
>> > - various small drawing issues
>> > - slow when exporting features with buffers (r.grow is slow, probably
>> > because it's a script)
>> Not sure but r.buffer would be appropriate/faster?
> I considered that but the cells grown by r.buffer have different values
> than the original ones, so I would have to reclassify it, so I am not sure
> if it would be faster in the end.
> Thanks for your feedback!
> Anna
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141120/57ca815b/attachment.html>
