[GRASS-user] Problem with r.basin in grass7
Helmut Kudrnovsky hellik at web.de
Thu Nov 20 02:52:38 PST 2014
> c) Try to use the NC dataset
now tested here with NC dataset (see also
http://grasswiki.osgeo.org/wiki/R.basin; the coordinates are taken from the
wiki)
r.info map=elevation at PERMANENT
 | Map:      elevation at PERMANENT            Date: Tue Nov  7 01:09:51 2006
 | Mapset:   PERMANENT                      Login of Creator: helena
 | DataBase: C:\grassdata
 | Title:    South-West Wake county: Elevation NED 10m ( elev_ned10m )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 255
 |   Data Type:    FCELL
 |   Rows:         1350
 |   Columns:      1500
 |   Total Cells:  2025000
 |        Projection: Lambert Conformal Conic
 |            N:     228500    S:     215000   Res:    10
 |            E:     645000    W:     630000   Res:    10
 |   Range of data:    min = 55.57879  max = 156.3299
 |   Data Description:
 |    generated by r.proj
 |   Comments:
 |    r.proj input="ned03arcsec" location="northcarolina_latlong" mapset="\
 |    helena" output="elev_ned10m" method="cubic" resolution=10
then
g.region -p -a rast=elevation at PERMANENT align=elevation at PERMANENT
projection: 99 (Lambert Conformal Conic)
zone:       0
datum:      nad83
ellipsoid:  a=6378137 es=0.006694380022900787
north:      228500
south:      215000
west:       630000
east:       645000
nsres:      10
ewres:      10
rows:       1350
cols:       1500
cells:      2025000
(Thu Nov 20 11:29:22 2014) Befehl ausgeführt (4 Sek)
 and
r.basin --verbose map=elevation at PERMANENT prefix=a
coordinates=636654.791181,218824.126649 dir=C:\tmp\rbasin threshold=40
(Thu Nov 20 11:40:48 2014) Befehl ausgeführt (7 Min 0 Sek)
r.basin finishes. as Margherita already mentioned, the region resolution has
to be aligned to the DEM resolution.
have a look at r.info map=elevation at PERMANENT  :
 |   Comments:
that can be a starting point for the reprojection of your NED DEM (in
geographic coordinates) to a projected location.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-r-basin-in-grass7-tp5169155p5173992.html
Sent from the Grass - Users mailing list archive at Nabble.com.
