[GRASS-user] Loading JSON data in GRASS
arighna roy roy.arighna at gmail.com
Sat Nov 29 21:10:00 PST 2014
 I am trying to append points to a new map patch_map6.
v.patch -e input=patch_map1 output=patch_map6
When I run the above command I get the following error.
ERROR: Key column not found
I don't know which column it is looking for.
Roy
