[GRASS-user] Grass70 win7 r.basin
José Anderson joseandersonbatista at gmail.com
Wed Oct 1 14:09:13 PDT 2014
Ok, César, Margherita,
maybe another issue (remembering I'm on grass7/win7) is installation
of dependences of r.basin: r.stream.stats r.stream.distance and
r.stream.order are missing because g.extension returns "File is not a
zip file" when trying to add them.
The rest r.stream.basins and r.stream.extract are present.
Could that be an issue?
Tks
2014-10-01 15:52 GMT-03:00 César Augusto Ramírez Franco <caesarivs at gmail.com>:
> Please keep the conversation on the list.
> Please refer to [1] for detailed instructions on the proper way of inputting
> the coordinates into the module. The pair of coordinates should be similar
> as the ones used on r.water.outlet, you must tell the module where in the
> map is the outlet of the basin you're trying to analyze.
> [1] http://grasswiki.osgeo.org/wiki/R.basin#r.basin_for_GRASS_7
> 2014-10-01 12:22 GMT-05:00 José Anderson <joseandersonbatista at gmail.com>:
>> C,
>> I'm picking them from the vector streams from r.stream.extract it comes up
>> from Grass picking points from geometry.
>> I dont know what 'near' means..
>> Thanks
>> Em 01/10/2014 13:08, "César Augusto Ramírez Franco" <caesarivs at gmail.com>
>> escreveu:
>>> Maybe you're picking the wrong pair of coordinates,
>>> Are you picking them upstream from the basin outlet? I mean, near the
>>> outlet but a little upstream
>>> 2014-09-29 17:20 GMT-05:00 José Anderson <joseandersonbatista at gmail.com>:
>>>> Dear all,
>>>> in the addon r.basin, the help says that basin output coordinates must
>>>> be picked up from some vector feature, the river network, which is
>>>> generated by the addon r.stream.extract.
>>>> That means I have the utm elevation raster and successfully ran
>>>> r.watershed for accumulation raster on grass70/win7.
>>>> However, despite the plugin get steps 1 through 4 without errors, it
>>>> cannot complete the area delineation.
>>>> I have tried, both, picking a utm point from point geometries and from
>>>> line geometries.
>>>> The message I get is:
>>>> An Error has occurred.
>>>> Please try with another pairs of outlet coordinates.
>>>> Have anybody tried r.basin from grass70 on win7?
>>>> Thanks in advance.
>>>> Jose Anderson
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Laboratorio de Sistemas Complejos Naturales
>>> Escuela de Geociencias
>>> Facultad de Ciencias
>>> Universidad Nacional de Colombia - Sede Medellín
>>> Teléfono: (57-4) 430 9369 - 300 459 6085
