[GRASS-user] fatal error: 'libintl.h' file not found (OSX)
Svein Harald Sønderland snarrald at gmail.com
Wed Oct 15 13:57:05 PDT 2014
I upgraded from v6.4.3 to v6.4.4 and used the KyngChaos installer
package. After having installed all the necessary packages listed on
that page the error message about libintl.h was no longer appearing.
Using this version I currently have no problems neither installing nor
using the addons I need for my work.
Prior to using KyngChaos installer package I tried v6.4.5-svn from
Michael Barton, but in many cases the layers did not show anything
except for blank layers. The rasters could be selected, but nothing
appeared on screen. Due to this I quickly jumped over to the KyngChaos
package, and it luckily worked better (for me).
Thank you all for your helpful replies, as of now everything seemingly
works as it should.
Best wishes,
On Wed, Oct 15, 2014 at 3:43 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> Right, so we're back to the problem, if libintl.h is bundled in the GRASS app include dir, why isn't it found?  I just looked, yes it's there, in the right place, it should work.
> Svein, is there more before the error?  I'm looking for a line that starts with 'gcc' or 'clang'.
> On Oct 15, 2014, at 1:08 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, Oct 15, 2014 at 1:57 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>> I do bundle it in my GRASS binaries.
>>> My point is that there is no functional reason that internationalization (which is otherwise optional in configuration for GRASS) should be needed to compile r.stream. extract.
>> But don't you compile with --with-nls support? Then it is needed as it
>> is for most other commands which come with gettext enabled messages.
>>>>> On Oct 12, 2014, at 3:23 PM, Svein Harald Sønderland <snarrald at gmail.com> wrote:
>>>>>> Anyone know how to get the r.stream addons to work on mac??
>>>>>> When trying to install I get this error:
>>>>>> /Applications/GRASS/GRASS-6.4.app/Contents/MacOS/include/grass/glocale.h:9:10:
>>>>>> #include <libintl.h>
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
