[GRASS-user] OSX Yosemite - GRASS 6.4 stopped working
Carlos Grohmann carlos.grohmann at gmail.com
Mon Sep 1 09:54:58 PDT 2014
Thanks Tom,
but I couldn't replicate your workaround. You mean the term window that
opens when GRASS is started "normally" (from dock or Application)?
If so, mine was a bit fast and I couldn't hit ctrl-C fast enough to stop it
in a normal term window, just pasting the line you provided also returned
me the same error as before (No such file or directory)
best
Carlos
On Mon, Sep 1, 2014 at 1:48 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> Carlos,
> I have seen the same thing; here is what I figured-out as a brute force
> work-around:
> (1) in the TERM window that pops-up do Control-C
> (2) copy and paste:
> /Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh
> (or the GRASS 7 equivalent)
> (3) <RETURN>
> This works every time I get this + it seems to temporarily 'fix' the
> problem...
> Cheers!
> Tom
> On Mon, Sep 1, 2014 at 11:00 AM, Carlos Grohmann <
> carlos.grohmann at gmail.com> wrote:
>> Hi all
>> I'm running OS X Yosemite Beta, and my GRASS install just stopped
>> working. It was running fine until last week, but now I can't open it, with
>> the following error msg:
>> Last login: Mon Sep  1 11:37:04 on ttys002
>> '/Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh';
>> exit
>> GuanoBookPro:~ guano$
>> exit
>> -bash:
>> /Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh:
>> logout
>> [Process completed]
>> The same happens with GRASS-7
>> I don't recall updating anything (maybe some automatic update happened in
>> the background), and I already tried to reinstall GRASS.
>> Trying to run grass.sh from /Applications/GRASS-6.4.app/Contents/MacOS/
>> will not work as well, first with a Gis_set Error about the splash screen
>> (should a missing splash screen gif cause an error on startup??), and after
>> it, with a python error:
>> Starting GRASS ...
>> Traceback (most recent call last):
>>   File "./etc/wxpython/gis_set.py", line 1003, in <module>
>>     GRASSStartUp = StartUp(0)
>>   File
>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line
>> 8631, in __init__
>>     self._BootstrapApp()
>>   File
>> 8196, in _BootstrapApp
>>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>   File "./etc/wxpython/gis_set.py", line 978, in OnInit
>>     StartUp = GRASSStartup()
>>   File "./etc/wxpython/gis_set.py", line 95, in __init__
>>     versionFile = open(os.path.join(globalvar.ETCDIR, "VERSIONNUMBER"))
>> IOError: [Errno 2] No such file or directory: './etc/VERSIONNUMBER'
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> So, I went and reinstall wxpython, but again with no success.
>> any help at this point is very much welcome
>> best
>> Carlos
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com
>> http://orcid.org/0000-0001-5073-5572
>> ________________
>> Can't stop the signal.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140901/0b216366/attachment-0001.html>
