[GRASS-user] re-order boundaries by relative position along polyline
Thomas Adams tea3rd at gmail.com
Sun Apr 5 10:48:30 PDT 2015
Hi Dylan!
(I'm about to start a new position — more on that later). This may help…
I had a problem somewhat analogous to this a little while ago, where I
needed to create a text file that, among a couple of other things, needed
to identify the 'downstream' pixel for all grid cells within a basin area.
I was able to do that with help here, but an issue I had was that the
integer IDs needed to be numbered from 0-N in basically upstream to
downstream order, but after my GRASS analysis I had IDs with some large
number ranging to some other very large number for the IDs and the
'downstream IDs' (with values skipped and not in order). I got help writing
a Perl script that uses hashes for a lookup table to relate the old ID to
the new ID.
Perhaps you could do something like this, starting with a new vector map
(copy) where you could simply update the attributes using an SQL query?
Some coding would be needed, obviously…
Just my 2 cents…
Cheers!
Tom
On Thu, Apr 2, 2015 at 6:31 PM, Dylan Beaudette <dylan.beaudette at gmail.com>
wrote:
> Hi,
> Once again, I am reminded that complex spatial analysis in other software
> can usually be reduced to a couple of lines of code in GRASS-- thanks!
> Here is a fun question. Suppose you have a set of line segments, or
> boundaries that are the result of a digitizing process that generated
> segments out of "order":
>       2             4              1           3
> O---------+-----------------+------------+------O
> 'O' = start / end point
> '+' = vertex
> ... in this case "order" is associated with order in which records appear
> in the attribute table and the order in which segments are drawn on the
> screen.
> Is there a module, or set of modules that could be used to re-order the
> segments so that the order of records in the attribute table and drawing
> order is:
>       1             2              3           4
> Note that I do not wan't to shuffle the linkages between geometry and
> attributes, rather, I would like to re-order the segments and attribute
> table according to the linear position within the set of contiguous
> boundaries or polyline.
> Here is an example set of lines in ASCII format, WGS84 GCS.
> ORGANIZATION:
> DIGIT DATE:
> DIGIT NAME:   dylan
> MAP NAME:
> MAP DATE:     Thu Apr  2 11:46:34 2015
> MAP SCALE:    1
> OTHER INFO:
> ZONE:         0
> MAP THRESH:   0.000000
> VERTI:
> B  6 1
>  -118.71960108 36.71846736
>  -118.71946261 36.71783146
>  -118.71905508 36.71717314
>  -118.71863837 36.71610377
>  -118.71807413 36.71546352
>  -118.71786286 36.71527706
>  2     132
> B  3 1
>  -118.7153795 36.73403608
>  -118.71537992 36.73272737
>  -118.71538933 36.73177277
>  2     133
> B  3 1
>  -118.71536851 36.76205202
>  -118.7153724 36.7609144
>  -118.71537619 36.75980591
>  2     150
> B  2 1
>  -118.73128842 36.69749903
>  -118.73130166 36.69760244
>  2     175
> B  5 1
>  -118.7153944 36.73125742
>  -118.71573607 36.73044156
>  -118.71618977 36.72875872
>  -118.71651025 36.72811846
>  2     581
> B  15 1
>  -118.71661716 36.72766138
>  -118.71660977 36.7273294
>  -118.71645785 36.72668322
>  -118.71689758 36.7261392
>  -118.71724087 36.72567564
>  -118.71747107 36.7248177
>  -118.71753527 36.72390024
>  -118.71787045 36.72307308
>  -118.71797278 36.72237579
>  -118.71781832 36.72073331
>  -118.71825483 36.72004703
>  -118.71908689 36.71948153
>  -118.71963768 36.71863545
>  2     602
> B  8 1
>  -118.7180943 36.70872005
>  -118.71827421 36.7083356
>  -118.71841915 36.7080259
>  -118.7190169 36.70752707
>  -118.72008403 36.70694237
>  -118.72042476 36.70636815
>  -118.72049695 36.70608245
>  -118.7212077 36.70547966
>  2     604
> B  15 1
>  -118.721692  36.70506892
>  -118.72256889 36.70442599
>  -118.72372477 36.702873
>  -118.72417965 36.70213899
>  -118.72496002 36.70190631
>  -118.72660809 36.70183505
>  -118.72765407 36.70118732
>  -118.72831767 36.70100376
>  -118.72866574 36.7007615
>  -118.72887421 36.70026501
>  -118.72998965 36.69849669
>  -118.73066541 36.69798083
>  -118.73118943 36.69770441
>  2     609
> B  8 1
>  -118.7153867 36.75138736
>  -118.7153804 36.7500365
>  -118.7153634 36.7464107
>  -118.7153465 36.742785
>  -118.7153296 36.7391593
>  -118.71533791 36.73753527
>  -118.7153438 36.7363838
>  2     610
> B  13 1
>  -118.71763335 36.71507451
>  -118.71748992 36.71480774
>  -118.71754381 36.71369999
>  -118.71750723 36.7131568
>  -118.71786592 36.71228789
>  -118.71745106 36.71129755
>  -118.71716489 36.71079564
>  -118.71709787 36.71043286
>  -118.71712906 36.71006868
>  -118.71740871 36.70978478
>  -118.717644  36.709369
>  2     612
> B  7 1
>  -118.71411256 36.77582538
>  -118.71445897 36.77550631
>  -118.71478471 36.77508229
>  -118.7149828 36.77446623
>  -118.71532537 36.77406797
>  -118.7153339 36.7717931
>  -118.71534777 36.76808916
>  2     613
> B  3 1
>  -118.71536   36.7645405
>  2     622
> B  4 1
>  -118.7153848 36.7572883
>  -118.7153973 36.7536622
>  2     623
> I have been able to convert these segments into polylines, however, I am
> not sure how one would go about computing the position along the polylines.
> Perhaps a linear referencing system?
> Thanks!
> Dylan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150405/bcce41ad/attachment.html>
