[GRASS-user] v.clean error threshold under 2 meters
Pierluigi De Rosa pierluigi.derosa at gfosservices.it
Tue Apr 7 02:09:41 PDT 2015
Dear all,
I'm running under an XY location (uprojected).
Could be this the problem?
We are using a local zero not linked to any reference system.
Here the output:
g.proj -w
XY location (unprojected)
g.region -p
projection: 0 (x,y)
zone: 0
north: 1
south: 0
west: 0
east: 1
nsres: 0.0001
ewres: 0.0001
rows: 10000
cols: 10000
cells: 100000000
This is the output of v.clean
v.clean input=rill_800_parcellaB_polyline at pierluigi output=rill_800_parcellaB_prune tool=prune threshold=0.1
Tool: Threshold
Prune: 0.1
Tool: Prune lines/boundaries
0 vertices from input 11742 (vertices of given type) removed, i.e. 0.00 %
Thanks
Pierluigi
----- Messaggio originale -----
Da: "Markus Neteler" <neteler at osgeo.org>
A: "Pierluigi De Rosa" <pierluigi.derosa at gfosservices.it>
Cc: "GRASS user list" <grass-user at lists.osgeo.org>
Inviato: Lunedì, 6 aprile 2015 21:28:14
Oggetto: Re: [GRASS-user] v.clean error threshold under 2 meters
Hi Pierluigi,
On Thu, Apr 2, 2015 at 11:34 AM, Pierluigi De Rosa
<pierluigi.derosa at gfosservices.it> wrote:
> Dear all,
> I have a unusual system unit.
Please tell us which :-)
> I'm working on a parcel unit for rill
> analysis. I'm able to extract the network and I would prune a bit the
> resulting output.
> All the parcel I'm studying is 10 meters wide and 22 meters long, the mean
> average distance between the streams is about 1-2 centimetres. I need to
> remove nodes in a threshold of 0.005 meters (half centimetre) but I'm having
> problem assigning such threshold to v.clean
> I'm running GRASS7.
> If I use these thresholds ( 0.005, 0.01,1,) no points are removed.
> The first valid working threshold is 2 meters.
> Maybe v.clean does not accept value under 1 meter or I'm doing something
> wrong?
v.clean should accept "any" value (and we have used GRASS GIS with
microscope data in the nanometer scale).
Could you post the output of
g.region -p
g.proj -w
best
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150407/4b77e9f1/attachment.html>
